Lighting HID/Xenon kits, Retrofits and Associated Topics
foglight wiring without harness, relay?
Old Jan 13, 2008 | 09:22 AM
prelude-all-the-way's Avatar
Default foglight wiring without harness, relay?
I bought the jdm yellow foglights and installed them to my parking lights and they worked fine for a year and now the amps are to high and the fuse keeps blowing.
SO i bought the jdm switch and a 4 pin 40 amp relay. My question is does anyone have a wiring diagram? and do I need a fuse runing to the battery? If not any suggestions to wire them up need help cause im selling the car and i dont have the oem harness or the connectors?
Thanks rob
Old Jan 13, 2008 | 12:29 PM
Default Re: foglight wiring without harness, relay? (prelude-all-the-way)
is it safe to just run the fogs with the parking lights on a 30 amp fuse instead of 20 amp
it works with the 30 but not the 20
Old Jan 13, 2008 | 12:37 PM
bpr0422's Avatar
search the WHOLE site for archived threads on foglights...
and you should get this: https://honda-tech.com/zerothread/1812043
Old Jan 13, 2008 | 12:48 PM
Default Re: foglight wiring without harness, relay? (bpr0422)
so im good
but do i need 15 gauge wire insted of whatever oem gauge is?
Old Jan 13, 2008 | 01:44 PM
bpr0422's Avatar
never replace a fuse with a larger rating fuse.
when a fuse blows, its protecting the circuit from overloading...
if you overload the circuit, you risk electrical failure which could lead to an electrical fire.
if you just want the foglights to turn on when your parking lights are on... follow that diagram.. but replace the coil in with the parking light wire...
VegasEg8
Dec 20, 2013 08:27 AM
CompanyFlow
Audio / Security / Video
Jun 14, 2010 09:36 PM
97BB6Type-SH
Nov 24, 2008 06:46 PM
Kr4nG
May 18, 2008 05:10 AM
djdc2
Oct 15, 2006 01:59 PM
