cooling system pressure
Old Jan 10, 2003 | 07:28 AM
TurboedGSR's Avatar
Default cooling system pressure
Whats the highest pressure it will see.
Old Jan 10, 2003 | 07:46 AM
TurboedGSR's Avatar
Default Re: cooling system pressure (TurboedGSR)
the reason i'm asking is because i've seen many people use earls fittings on all their connections (vaccum sources too?). I have ss braided hose for any coolant/vac line passing close by the turbo, but i cant afford/dont want to spend all that $$$ on fittings. so i was thinking of using these just to cover up the ugly wires sticking up:
they can handle 90psi
Old Jan 10, 2003 | 10:08 AM
BudaKai's Avatar
I used stainless because I already had them and they were free. I think they use the EARL's fitting for peace of mind so to say. You should've trimmed those ugly wires to prevent any kind of movment with the braiding. Unless you like leaks. Can they really handle that much? I never knew. Why not just convert oner to AN fittings. I've seen it done and it looked really nice for a CVCC Civic engine bay with the dinky 1200.
Old Jan 11, 2003 | 01:18 PM
TurboedGSR's Avatar
Default Re: cooling system pressure (tzsir)
price
these are $7 a pair. if i were to convert i'd need ntp>an adapter fittings, a couple of -4an tee's and the hose fittings. comes out to be much more expensive and looks very similar. i'm pretty sure the people who do use real earls fitting for the vac lines only do it for looks. same for fuel lines. its definetly not needed for the regular daily driver. i guess you could call it "rice"
ty521825
Mar 20, 2010 07:11 AM
monicle
22
Apr 13, 2007 11:55 AM
RTW DC2R
May 1, 2006 04:31 PM
bayoufrogg
Aug 26, 2005 01:04 PM
Xerxes
Jan 30, 2002 10:29 PM
