cooling probs
Old Aug 12, 2002 | 10:08 AM
the1eddins's Avatar
Default cooling probs
i just helped install a turbo on one of my friends 96 civic 2 door. it has the 1.6 sohc vtec with a itty bitty turbo(i dont know what it is but it came off of a 2g rx7 i think- it spools at like 2250 rpm). he's running 6-7 lbs with a vortech fpr, and a front mount that stretches across the whole bumper support... he said it was getting really hot really quick, but it would never peg out the temp needle. any quick suggestions/ tips?
Old Aug 12, 2002 | 10:44 AM
CovertFI's Avatar
Default Re: cooling probs (the1eddins)
maybe the ic is blocking all of the air. tell him to remove the upper grill in the bumper and see if that helps a little. i took mine out a long time ago.
Old Aug 12, 2002 | 11:21 AM
W.Zero's Avatar
Default Re: cooling probs (CovertFI)
the IC might be blocking air to the radiator try to have him switch up to a dual core radiator.
Old Aug 12, 2002 | 01:19 PM
98civicEX's Avatar
Default Re: cooling probs (W.ZeroB18C1T)
hook up a switch, have the fan running whenever the car is on...
Old Aug 12, 2002 | 03:32 PM
Hybrid's Avatar
Default Re: cooling probs (98civicEX)
The fan switch is a good trick, but don't fully do the job.
Me and a pal of mine are running restrictor type plates in our thermo housings instead of the regular thermostat.
Anyway I did mine tonight and the engine runs way cooler, my buds is the same way.
I just cut the guts out of the old thermo, then welded a washer on the round housing with approx a 3/4 hole to semi restrict the flow and vola.
I'm sure you could prob get a washer to fit, the only prob I could see is the actual width.
(Car is not winter driven)
Cheers
Nichol Viena
Aug 15, 2015 04:52 AM
Mootspoints
Jun 25, 2015 03:16 AM
asoRm
Aug 13, 2014 12:10 PM
peel17
Feb 16, 2005 10:28 AM
ItalynStylion
Aug 8, 2004 11:11 PM
