Where to get pusher fan?
Old Apr 15, 2004 | 07:17 PM
hoggy's Avatar
Default Where to get pusher fan?
I need a pusher fan real bad for my car now and I'm pretty broke. Whats the cheapest once I can get that will do the job. Its going on a turbo b16 running 6spi intercooled.
Old Apr 15, 2004 | 09:45 PM
hoggy's Avatar
Default Re: Where to get pusher fan? (hoggy)
to the top
Old Apr 15, 2004 | 10:54 PM
u2civic1's Avatar
check pepboys or autozone they are usually 60 bucks or so
Old Apr 16, 2004 | 03:58 AM
NapTownSi's Avatar
Default Re: Where to get pusher fan? (u2civic1)
I got two from autozone (radiator fan and condensor fan), they were like $68 (12") a piece.
-Mark
Old Apr 16, 2004 | 04:15 AM
TurboBumblBee's Avatar
ill sell you a stock integra gsr fan, just replaced the radiator and this thing is sitting here... lmk if your intersted
Old Apr 16, 2004 | 04:29 AM
dasher's Avatar
May I suggest that you buy a higher quality pusher fan like permacool sells(more cfm flow) to make up for the loss in efficiency inherent in using a pusher instead of a puller ..
Old Apr 16, 2004 | 08:11 AM
hoggy's Avatar
Default Re: Where to get pusher fan? (dasher)
Where would I get a nicer fan like you are suggesting? And how much would one run?
Old Apr 16, 2004 | 08:27 AM
PM-Performance's Avatar
i have the $60 imperials from Autozone and works awesome .
Old Apr 16, 2004 | 08:34 AM
ladysman's Avatar
Default Re: Where to get pusher fan? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">i have the $60 imperials from Autozone and works awesome .</TD></TR></TABLE>
Old Apr 16, 2004 | 08:39 AM
dasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoggy &raquo;</TD></TR><TR><TD CLASS="quote">Where would I get a nicer fan like you are suggesting? And how much would one run?</TD></TR></TABLE>
summit .. 60-80 bucks
Old Apr 16, 2004 | 08:50 AM
AVATAR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher &raquo;</TD></TR><TR><TD CLASS="quote">May I suggest that you buy a higher quality pusher fan like permacool sells(more cfm flow) to make up for the loss in efficiency inherent in using a pusher instead of a puller ..</TD></TR></TABLE>
Hit the nail on the head. If your gonna spend the $, spend alittle (literally)more and buy a Permacool/Profoam one from Jegs. It flows like 300cfm more than the ones you buy from Autozone and OReilys (Hayden) at a lower amp draw.
Modified by AVATAR at 12:23 PM 4/16/2004
Old Apr 16, 2004 | 08:51 AM
Vanilla Ic3's Avatar
This is what I'm running- these fans push even more cfm than permacool yo
25,000 cfm
Old Apr 16, 2004 | 08:52 AM
dasher's Avatar
Default Re: Where to get pusher fan? (Vanilla Ic3)
Ahhhhhh .. hell yeah! Thats sooo Tite, you will get more mad powa from that!!!
Old Apr 16, 2004 | 09:00 AM
Werd. They like 1200 bones tho yo. Not 60.
Old Apr 16, 2004 | 10:41 AM
RedStarGsr's Avatar
can anyone post pictures of their pep boys / autozone fan installed? im looking into getting one...but im not sure how much CFMs or size i need for my half slab del sol radiator---gracias.
Old Apr 16, 2004 | 10:43 AM
porsche997dc2's Avatar
Default Re: (RedStarGsr)
check summit racing fans. I had used them with good result.
Old Apr 16, 2004 | 12:19 PM
AVATAR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dasher &raquo;</TD></TR><TR><TD CLASS="quote"> . . . to make up for the loss in efficiency inherent in using a pusher instead of a puller ..</TD></TR></TABLE>
BTW, what make you think that a puller is less efficient than a puller?
RedStarGSR - I did a writeup on mine not too long ago, though it's not on a stock rad. https://honda-tech.com/zerothread?id=750219
Philo also did a writeup awhile ago, search in the Forced Induction Archives.
Old Apr 16, 2004 | 12:41 PM
dasher's Avatar
Default Re: Where to get pusher fan? (AVATAR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR &raquo;</TD></TR><TR><TD CLASS="quote">
When their is direct resistance behind the fan (ie the condensor, or radiator) it makes the fan less efficient because it has to push air through this resistance, causing turbulance... A puller setup is more efficient because their isnt direct resistance behind the fan to cause turbulance in the airflow.. so the fan can more efficiently pull the air through without extra turbulance....
It is very well known that Switching a fan from a puller to a pusher will only be 80% as efficient.
Old Apr 16, 2004 | 03:36 PM
AVATAR's Avatar
. . . It is very well known that Switching a fan from a puller to a pusher will only be 80% as efficient.</TD></TR></TABLE>
Weird . . . that must be why we have so many mercedes at our shop running them (pusher), and they arent doing it for space. What you say makes sense, but I'm just wondering if you have any actual datalogs, or if it's just theory. I wouldnt think it would make a difference enough to notice at all.
Old Apr 16, 2004 | 04:03 PM
dasher's Avatar
Weird . . . that must be why we have so many mercedes at our shop running them (pusher), and they arent doing it for space. What you say makes sense, but I'm just wondering if you have any actual datalogs, or if it's just theory. I wouldnt think it would make a difference enough to notice at all.</TD></TR></TABLE>
I just assummed that it was common knowledge ... oh well...
Here is one source amoungst many directly from the larger manufacturer of fans ...
http://www.permacool.com/Catalog/Cat_page16.html
Old Apr 16, 2004 | 04:36 PM
AlphaKennyWun's Avatar
I have an almost new 10" summit racing slim fan for $40.
Old Apr 16, 2004 | 07:32 PM
AVATAR's Avatar
Well you know what they say about assumptions . . . I guess it makes sense. Whatever *shrugs shoulders*
Modified by AVATAR at 12:03 AM 4/17/2004
Old Apr 16, 2004 | 08:27 PM
slim9300's Avatar
Default Re: Where to get pusher fan? (Turbo Chris)
I am going to buy one of the Summit or Jegs pushers. But I have two questions first. How do you attach the fan to the stock radiator? Do you just screw it into the fins? From the pictures, that's what it looks like, but that can't be right, can it? I have the same radiator as below, and I have no A/C, so I only need one on the passanger side, right? Or do I need two?
Thanks in advance.
Old Apr 16, 2004 | 08:55 PM
slim9300's Avatar
Default Re: (calmweed)
More help would be greatly appreciated.
Old Apr 16, 2004 | 09:06 PM
AVATAR's Avatar
Default Re: (slim9300)
I cant answer your A/C ? but regarding the mounting, think 4 zip ties. They dont look like conventional zip ties but they work the same way.
1baddturbosi
10
Nov 18, 2007 04:19 PM
platinum00
Jul 30, 2006 07:55 AM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
InLimbo87
Jul 21, 2004 07:22 AM
KOALA YUMMIES
Nov 26, 2003 09:32 PM
