!!Coolant Leak between head and block!!
Old Aug 30, 2005 | 10:09 PM
ki11a8ee's Avatar
Default !!Coolant Leak between head and block!!
Hello I just started up my motor for the first time today on my built h22 motor. The block was step decked and i am using the stock h22 headgasket. i went with stock bore. I used ARP headstuds and followed the directions carefully. So while it was warming up there was coolant leaking between the head and block at some areas very little. So i was wondering what the problem could be i had the head checked out and block checked out for perfect flat surface what could the problem be? HELP ME
THanks in advance
Old Aug 31, 2005 | 05:02 AM
ki11a8ee's Avatar
Default Re: !!Coolant Leak between head and block!! (ki11a8ee)
Do u guys think i need to use another headgasket for step deck?
Old Aug 31, 2005 | 07:14 AM
earl's Avatar
Are you positive you did not install the gasket with the up side facing down?
Second thought...if you are using a steel gasket on a steel sleeve that is cut above the deck...nothing is left that will compress. The head MUST warp to compress and seal (not a good thing). Maybe your head is not warping to seal.
The latest thinking from automotive engineers is that the best sealing surface available for aluminum blocks with mls headgaskets is a micro smooth flat surface. Stepped decks are not the way to go anymore.
Old Aug 31, 2005 | 07:17 AM
turbosi03's Avatar
are you sure its the HG leaking and not some coolant hose? I had many hose leaks and the ones near the T stat (B series motor) leaks in a way that it looks like the gasket is leaking because the coolant found its way around the HG.
-check oil
-check coolant
make sure there's no mixing. double check all hose clamps!!
OEM HG works for stepped deck.
good luck
Old Aug 31, 2005 | 02:42 PM
ki11a8ee's Avatar
Default Re: !!Coolant Leak between head and block!! (turbosi03)
I checked the coolant hoses and im sure its coming from the head. I took the head off and im gonna double check to make sure its flat.
thanks
Old Aug 31, 2005 | 03:44 PM
greenhotrod's Avatar
we had the same problem with a stepped deck on a b18c.we had the block decked to eliminate the step and switched over to the new sce copper gasket with a built in o-ring-problem solved.
Old Aug 31, 2005 | 06:56 PM
ki11a8ee's Avatar
Default Re: !!Coolant Leak between head and block!! (greenhotrod)
man that will be my last resort i just put the motor in is there any other way?
Old Aug 31, 2005 | 07:00 PM
Adi Radoncic's Avatar
On Fire!
what did you torqe the studs to, did you follow the owners manual torqueing sequence?
Old Sep 1, 2005 | 04:55 AM
ki11a8ee's Avatar
Default Re: !!Coolant Leak between head and block!! (Adi Raaa)
Yea I have the arp headstuds and i torque it down to 70lbs i believe. And i also did the 3 different torque sequences.
Old Sep 1, 2005 | 06:02 AM
Boosted Chemist's Avatar
Default Re: !!Coolant Leak between head and block!! (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Are you positive you did not install the gasket with the up side facing down?
The latest thinking from automotive engineers is that the best sealing surface available for aluminum blocks with mls headgaskets is a micro smooth flat surface. Stepped decks are not the way to go anymore.</TD></TR></TABLE>
now you tell me this after i got a benson steped deck this january?
I thought they were better than copper o ring blocks
Old Sep 1, 2005 | 06:54 AM
earl's Avatar
Default Re: !!Coolant Leak between head and block!! (Boosted Chemist)
Are you having problems? If so, we will fix it for free. As I have said, this does not happen to every combination. Only a few cases. But a few is too many. Sleeved blocks have evolved like every other part has also.
Old Sep 1, 2005 | 08:12 AM
no no problems, other than a head and block oil leak but i suspect the valve cover gasket. but i only have 500 miles on my setup and i have to drive 400 miles to school this monday, so i guess we will see.
Old Sep 1, 2005 | 08:14 AM
wantboost's Avatar
Who is Mr Robot?
i remember you telling me this when i called you
Old Sep 1, 2005 | 05:19 PM
ki11a8ee's Avatar
Default Re: !!Coolant Leak between head and block!! (wantboost)
How high are the steps anyways?
Old Sep 1, 2005 | 06:27 PM
earl's Avatar
Anywhere from .002-008"
Old Sep 1, 2005 | 07:23 PM
ki11a8ee's Avatar
Any step deck setups out there have any leaking problems with an oem gasket or maybe another gasket(sce copper gasket, cometic)?
thanks
ef9_b16a1
Oct 15, 2007 12:59 PM
boost fed ls
Dec 19, 2005 04:04 PM
omgwtfhaxnub
Mar 20, 2005 03:29 PM
ITR_1211
Jan 5, 2004 09:04 PM
syndicate43
Oct 13, 2002 07:38 PM
