Converting an internal to an external wastegate
Old Apr 6, 2005 | 06:25 PM
jsprelude's Avatar
Default Converting an internal to an external wastegate
I am running a greddy kit and how could i go about converting to an external wastegate. I know i would have to weld the internal wastegate whole shut. How would i go about welding on the external. Could you fabricate it to the greddy manifold? The reason im inquiring this is i have done a search and have found that the 18g will not boost over 15 psi without spiking and 18g are supposed to max out a 22 psi which should get you close to 400 horsepower!! My motor is built and i want to turn up the boost and make some good power!
Old Apr 6, 2005 | 06:58 PM
99blusi's Avatar
Default Re: Converting an internal to an external wastegate (jsprelude)
I've seen it done...one of the type R guys had his ported and welded and all that good stuff.
Old Apr 6, 2005 | 07:06 PM
jsprelude's Avatar
Default Re: Converting an internal to an external wastegate (99blusi)
my thing is how hard is it to do this because if its pretty easy i think it will really be worth it!
Old Apr 6, 2005 | 07:16 PM
PrettyLude's Avatar
its not that hard at all, hope you are handy with a welding machine
Old Apr 6, 2005 | 07:36 PM
jsprelude's Avatar
Default Re: (PrettyLude)
pics
Old Apr 6, 2005 | 09:24 PM
btotherizzle's Avatar
I will be welding a turbosmart 38mm to my greddy mani on my itr this week when i find time. So many parts to install so little time. Will post pics
Old Apr 7, 2005 | 07:55 PM
jsprelude's Avatar
Default Re: (btotherizzle)
anyone else with pics or advice
Old Apr 7, 2005 | 07:57 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (jsprelude)
the guys sn is like C C Fries or something like that
xander1100
Jun 27, 2009 10:56 AM
BDTURBO
Nov 5, 2004 08:05 PM
whackassfawker
Aug 13, 2004 08:51 AM
GorData
May 14, 2002 07:19 PM
