controlling boost on an internally gated setup.....?
Old May 22, 2004 | 12:21 PM
Black R's Avatar
25 Year Member
Default controlling boost on an internally gated setup.....?
I have a greddy 18g, and it is internally gated. How could I run 0psi after installing it, so I could drive it to the dyno without worries of boosting or overboosting.....
I believe it boosts 7psi stock? I assume later I could add a boost controller to run 9psi if i wanted.....?
Old May 22, 2004 | 12:33 PM
DaX's Avatar
DaX
Loved
Community Favorite
Try using wire to hold the flapper open...like wrap wire around the flapper's "arm" and run it somewhere where it will hold the gate open. To run more boost, use an MBC.
Old May 22, 2004 | 01:03 PM
Bailhatch's Avatar
Default Re: (DaX)
just pull out the cotter pin or take off the E-clip that holds the actuator arm to the flapper. You can just pull the actuator arm off the flapper and it won't boost. The wire idea will work but if the wire lets go you will instantly boost up to whatever the spring is set to.
Old May 22, 2004 | 01:08 PM
Cruiser G's Avatar
Default Re: (Bailhatch)
Or if your not driving too far you can just baby it so it will not boost.
Old May 22, 2004 | 01:10 PM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">just pull out the cotter pin or take off the E-clip that holds the actuator arm to the flapper. You can just pull the actuator arm off the flapper and it won't boost. The wire idea will work but if the wire lets go you will instantly boost up to whatever the spring is set to.</TD></TR></TABLE>
Haha, I never see the simple solution.
Old May 22, 2004 | 04:44 PM
TurblowR's Avatar
Default Re: (DaX)
i have the same dilemma. i was told just to unhook the charge pipe and stick a filter there. or u can just baby it all the way there and shift at 2k rpm (better safe than sorry). These are probably the best ways so you dont hit boost.
PS and if people honk at you, just flip them the ol' HT salute
VtecKiDD
Nov 18, 2006 03:54 PM
s2kkid
Jul 4, 2005 09:04 AM
hotimportcrx
May 27, 2005 01:20 PM
Black R
Mar 30, 2005 03:42 PM
