controlling the boost
Old Jul 19, 2001 | 04:33 PM
boostn5Ghaba's Avatar
Default controlling the boost
I just bought a greddy it for a gsr and the greddy turbo comes with an internal wastegate. How do I go about adjusting the boost with an internal wastegate? Do I have to buy a boost controller? Thanks in advance.
Old Jul 19, 2001 | 05:43 PM
G's Avatar
G
Default Re: controlling the boost (boostn5Ghaba)
There are many different ways to control the boost in any turboed car. Cheap way, get an air compressor 3 way bleeder/pressure regulator and you can adjust the bleed to control boost (not too consistant). You can get a ball and spring relief valve and manipulate it to control boost (my current set up), it holds the signal pressure to the internal WG back until the desired boost is reached then the spring collapses to release the pressure into the WG and opens it until the boost pressure is decreased, very consistant, but I have some issues with it. Then, you can go and get an expensive spring and ball pressure relief valve, exactly like mine but with better packaging and a nice sticker on the outside (about $120 worth of prettyness). Then lastly, an electronic boost controller. More expensive, and worth it. Sorry if it is a long reply, I am bored.......
Old Jul 19, 2001 | 05:52 PM
Default Re: controlling the boost (G)
that's very informative. Long replies are ok. Thanks for the info
Old Jul 19, 2001 | 05:55 PM
boomslang's Avatar
Build your own spring and ball bearing type, mine works great and cost about $4.
Old Jul 19, 2001 | 05:56 PM
b18bturbo's Avatar
the best method ofcourse is the electronic boost controlles. I actualy like the TurboxS products they are actually nice for the price. the manual controllers work like he said. Usually you can pick one up for under 100 bucks. if you want to try a small test look at cspeedracing.com and look at his homemade controller
Old Jul 19, 2001 | 09:34 PM
Default Re: controlling the boost (b18bturbo)
thanks b18bturbo. I think i'm going to try that first. Cheap is exactly what I'm looking for.
Sketch_hs
Aug 10, 2004 09:06 PM
_Endless_
Dec 17, 2002 10:57 PM
GettaluvR
Nov 2, 2002 10:38 AM
Duck Sauce
Aug 10, 2002 08:00 PM
Quetzolcotl
May 24, 2002 01:30 AM
