Continuation of the D series timing thread...
you guys are making it way harder than it is.
art is right, as long as the timing is synch'd it doesnt matter.
sohc cams run slightly less timing then your typical dohc cam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">you guys are making it way harder than it is.
art is right, as long as the timing is synch'd it doesnt matter. if the car likes 12 degrees or 14 degrees or even 18 degrees of timing at idle, so be it.
sohc cams run slightly less timing then your typical dohc cam. so run it more conservative and advance it until it stops making power.
But to start conservative you would want to take everything to 12*, or am I making this **** up in my head. Because if you sync it at 16, you are 4 degrees advanced on a stock Y8 map. Maybe it just makes sense in my head. I know it might be making it harder than it should be, but is logical to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">I told you I was right
Thanks tony1 for the help the other day.</TD></TR></TABLE>
I know it doesn't matter. But does anyone understand whta I am talking about. It is like taking a z6 distributer and cranking it forward 4*... isn't that essentially what you are doing, if you take the Y8 and put it at 16 instead of stock 12....
Here is what happens to a map when you change your base ignition advance:
Dial your dizzy in to match your BIA. End of story. The 12 degree's deal threw me off a bit before because I never encountered this before.
****... I should have saved it in higher resolution, lol. I'll repost it tomorrow if I'm not too hung over.
hey eat my ***, some of us have finals and are busy. when dont i help ur homo *** out.
my ringer on my phone is off, and my voicemail box is full, im not picking up the phone until exams are over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">Change it in hondata. It is just a pain in the *** to change it because you can't say, change all the values by 4 degrees, only percent.</TD></TR></TABLE>
eh?
eh?
my ringer on my phone is off, and my voicemail box is full, im not picking up the phone until exams are over. </TD></TR></TABLE>
I didn't mean it to sound like that. If it weren't for mase I would not know hardly anything about t00ning! Tony helped me figure out the D series issue... mase helped me with pretty much everything else I know.... besides how to have 3 somes. Because his *** doesn't know **** about those hahahahaha
I didn't mean it to sound like that. If it weren't for mase I would not know hardly anything about t00ning! Tony helped me figure out the D series issue... mase helped me with pretty much everything else I know.... besides how to have 3 somes. Because his *** doesn't know **** about those hahahahaha</TD></TR></TABLE>
As far as I know he's the 3some expert... but he likes to keep at least 2 dudes involved.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin »</TD></TR><TR><TD CLASS="quote">
eh?
That is exactly what I was trying to refer to. No one told me it could do that GRR...
So anyway good we were on the same damn page after all.
So hondata and uberdata have this after all.. I honestly can't believe that I never tried the addition button. What an ***. LoL
Well I learned something new today.
Modified by 93turbo16 at 12:37 AM 4/22/2005
eh?
</TD></TR></TABLE>That is exactly what I was trying to refer to. No one told me it could do that GRR...
ohsnapzafingcu
Engine Management and Tuning
14
Sep 28, 2009 07:54 PM
PINKS
May 29, 2006 09:22 AM
GReddyB18C
Sep 7, 2002 05:24 PM
