Considerations for Wastegate and BOV sizes?
Old Mar 24, 2003 | 04:13 PM
UtahRockabilly's Avatar
Default Considerations for Wastegate and BOV sizes?
What are the considerations for Wastegate and BOV sizes? What I am talking about is mm size as far as 35-45mm and what not. I know that boost levels are going to probably be the main consideration as to which you choose but at what boost level do you go up in mm size for each?
Old Mar 27, 2003 | 09:39 AM
Default Re: Considerations for Wastegate and BOV sizes? (UtahRockabilly)
bump to the top...tastes like chicken
Old Mar 27, 2003 | 04:46 PM
damn no one? bump to the top for one more try
Old Mar 27, 2003 | 05:47 PM
SpoolnG2's Avatar
what is the lowest boost u wanna run? and what is the highest boost u plan on running? tell me that, and i'll give u an answer.
Old Mar 27, 2003 | 06:38 PM
Default Re: Considerations for Wastegate and BOV sizes? (SpoolnG2)
well I am building an H22A turbo setup running from 10-15 psi
Old Mar 27, 2003 | 06:42 PM
DimSum321's Avatar
i heard 35mm is good for 20psi
Old Mar 27, 2003 | 06:44 PM
SpoolnG2's Avatar
Default Re: Considerations for Wastegate and BOV sizes? (DimSum321)
the tial 35mm sport is pobably the best for that setup. it has a 9lb stock spring and is capable of about 25psi. the difference is that the sport has a 35mm bottom and a 40mm top.
gaundy22
Dec 6, 2015 08:40 AM
turboek97
Sep 12, 2008 12:58 AM
ragethemachine86
Aug 14, 2006 01:25 PM
Spoold_R
May 13, 2003 05:21 PM
eg2turbo
Dec 9, 2002 09:51 AM
