Concerns over high boost.
Im ready to dyno run the new SC61. The set-up briefly:
- JE 9.0:1
- Darton sleeves
- Eagle H-Beams
- FAST ECU
- 65lb injectors
- Holley 255 FI fuel pump
- 3" Thermal exhaust
-.8 bar tial wastegate spring in a 38mm WG
- AEM fuel pressure regulator on AEM rail
Where's the weak link here? What wont hold up to 450+ HP? How far should
I push it? Im feeling unsure about those Eagle rod bolts. I appreciate your comments.
Modified by exsleeper at 2:17 PM 12/12/2003
Modified by exsleeper at 2:30 PM 12/13/2003
- JE 9.0:1
- Darton sleeves
- Eagle H-Beams
- FAST ECU
- 65lb injectors
i dont trust the eagles myself. how can you spend the extra $$$ on darton and skimp on the rods?? I would rather go GE and save some money there and throw some bulletproof pauters in there. just my opinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsleeper »</TD></TR><TR><TD CLASS="quote"> Im ready to dyno run the new SC61. The set-up briefly:
- JE 9.0:1
- Darton sleeves
- Eagle H-Beams
- FAST ECU
- 65lb injectors
I push it? Im feeling unsure about those Eagle rod bolts. I appreciate your comments.</TD></TR></TABLE>
You have a nice setup, 450 shouldnt be a problem with a good tuner. The rods are your weakpoint though.
- JE 9.0:1
- Darton sleeves
- Eagle H-Beams
- FAST ECU
- 65lb injectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">I also agree that the eagles will be fine.
However, you will most likely max out those injectors around 400whp.</TD></TR></TABLE>
agreed
agreed
I went on the RC injector page a while back and it said that I needed like 1400cc injectors to get around 500hp. If thats true then I'm way short with my 682cc's. Or are 1400's too much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsleeper »</TD></TR><TR><TD CLASS="quote">I went on the RC injector page a while back and it said that I needed like 1400cc injectors to get around 500hp. If thats true then I'm way short with my 682cc's. Or are 1400's too much.</TD></TR></TABLE>
Never use that injector calculator. It never seems to work for us Honda Peeps.
I would say at least 720cc's...but just to stay safe I would look into some Precision 880ccs...
That way to dont have to sell them if your looking for over 500hp one day.
Also, if the eagle hardware is a weak link for Honda's, as my honda friend is telling me (DSM's don't seem to have this issue, do we get a larger bolt then you?) then changing the rod bolts is easy, drop the oil pan and do that, its a messy few hours but its better then the alternative.
ItsStockOfficer: I posted again
ItsStockOfficer: Honda-Tech.com: Concerns over high boost.
maskednegator: i think you actually have to rethread the rods to do this
ItsStockOfficer: WTF
maskednegator: yeah
maskednegator: it ain't htat easy
ItsStockOfficer: Why the hell can't arp make a hard ware with the right pitch
maskednegator:
Me sticks to DSM advice
maskednegator: yeah
maskednegator:
Honestly, not only do your injectors seem to be a little weak and the rods not my choice, But is that IC in the picture the one you are using? Looks kind of small? I could be wrong but you may see some high end restrictions if its not big enough. Then again i dont know the specs on it so i could be completely wrong.
Good luck and it sounds like it will definately put some power down!
i hope people realize that eagle rods fail b/c of improper installation.
people say the bolts are the weak point...why?
improper torquing
Theres always gonna be people who hate a product b/c it failed for them, after that people jump on the bandwagon honda-tech is so famous for.
your rods are fine as long as they were torqued properly.
improper torquing
I indeed am suffering from intercooler envy right now. Im basically running a F-max kit and that is what came with it. I was thinking of going with a Precision product in this area also.
If I start losing sleep over the rod bolt torque, is it just a matter of dropping the oil pan to double-check or will it get more involved than that?
ridnmyhonda
Nov 4, 2003 12:03 AM
