Today's baseline dyno numbers
Old Dec 13, 2003 | 06:34 PM
Javier23's Avatar
Default Today's SC61 baseline dyno numbers
.8bar
251.2/177
1bar
289.5/200.6
Modified by exsleeper at 11:21 PM 12/13/2003
Old Dec 13, 2003 | 07:16 PM
ek9turbo's Avatar
Default Re: Today's baseline dyno numbers (exsleeper)
whats ur set up?
Old Dec 13, 2003 | 07:19 PM
Javier23's Avatar
Default Re: Today's baseline dyno numbers (ek9turbo)
B16block - 18c1 head and tranny - SC61 turbo. The set-up briefly:
- JE 9.0:1
- Darton sleeves
- Eagle H-Beams
- FAST ECU
- MSD 6AL + Blaster coil
- 65lb injectors
- Holley 255 FI fuel pump
- 3" Thermal exhaust
-.8 bar tial wastegate spring in a 38mm WG
- AEM fuel pressure regulator on AEM rail
Modified by exsleeper at 11:19 PM 12/13/2003
Old Dec 13, 2003 | 07:24 PM
mrDFWmechanic's Avatar
nice numbers
Old Dec 13, 2003 | 08:19 PM
FredoSP's Avatar
i think those #'s are a drop low. Are you at stock 81mm bore and B16 cams?
You have a 3" downpipe?
Just wondering
Old Dec 13, 2003 | 08:20 PM
Javier23's Avatar
Default Re: Today's baseline dyno numbers (FredoSP)
stock bore,stock cams, 2.25 DP.
Old Dec 13, 2003 | 08:24 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exsleeper &raquo;</TD></TR><TR><TD CLASS="quote">stock bore,stock cams, 2.25 DP. </TD></TR></TABLE>
ahh okay, that's what I figured, so then the #'s do add up correctly.
Im going with an SC61 @ 84.5mm bore and 2.5" DP and GSR cams, so at .8 bar (same spring as you) Im hoping to see around 320HP and maybe 215TQ? Ehh who knows.
Old Dec 13, 2003 | 08:25 PM
ATS*Mark's Avatar
OG triple OG
that dp is hurtin you
Old Dec 13, 2003 | 08:27 PM
Javier23's Avatar
Default Re: Today's baseline dyno numbers (Hella_JDM)
A custom 3 inch is in the works! Along with a better FPR and 1 bar spring. THEN, I'll be posting better numbers.. maybe next week.
Old Dec 13, 2003 | 08:37 PM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">that dp is hurtin you</TD></TR></TABLE>
agreed, the turbine outlet is like 2.7" or something like that?
Old Dec 13, 2003 | 09:28 PM
RobbieG35's Avatar
12 Years Strong
good numbers
Old Dec 15, 2003 | 07:15 AM
Javier23's Avatar
Old Dec 15, 2003 | 07:18 AM
BoostedsiR's Avatar
You need a bigger downpipe and dont be afaid to turn up the boost you should hit 400 no problem with some good standalone tuning. Have fun , you are going in the right direction
Old Dec 15, 2003 | 07:26 AM
TurboJesse
Guest
Posts: n/a
Default Re: Today's baseline dyno numbers (BoostedsiR)
those numbers seem a little low for your setup, i made more power and torque with alot smaller turbo, stock b16a and a really conservative tune @ less boost. Setup sounds sick though, def 400+ whp potential
Old Dec 15, 2003 | 07:39 AM
Johnyquest's Avatar
Default Re: Today's baseline dyno numbers (Mpir3)
WTF are you doiing with an sc61 on that motor? You only have power for 2k rpms... That must be fun
Old Dec 15, 2003 | 08:09 AM
JDogg's Avatar
Default Re: Today's baseline dyno numbers (Johnyquest)
take that ho out to 9000 or more. your power isnt hardly even peaking at 8500.
dyno w/the new dp then get back w/us. with the outlet on the turbo being bigger than your downpipe ur kickin your own ***
Old Dec 15, 2003 | 08:17 AM
BlueSi2k's Avatar
Default Re: Today's baseline dyno numbers (JDogg)
whats the a/f at?
Old Dec 15, 2003 | 08:40 AM
FredoSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">WTF are you doiing with an sc61 on that motor? You only have power for 2k rpms... That must be fun </TD></TR></TABLE>
umm not if ur redline is 9500 and u got GSR cams and an 84.5mm bore, duhh
Old Dec 15, 2003 | 09:04 AM
TRE_'s Avatar
Just out of curioustiy, is the torque always that low compared to HP on B16's? Nice numbers, BTW.
Old Dec 15, 2003 | 09:07 AM
hulkhb's Avatar
Not impressed
Old Dec 15, 2003 | 09:31 AM
Del_Slowest's Avatar
Default Re: Today's baseline dyno numbers (hulkhb)
I thought all dyno's had to cross at 5252rpm's. Its the way you calculate hp from torque. These are the first that i've seen that don't cross there. Can anybody explain this?
Old Dec 15, 2003 | 10:05 AM
st00pid's Avatar
Default Re: Today's baseline dyno numbers (Del_Slowest)
The scaling is different on the tq and the hp, thats why they dont cross on the graph.
Old Dec 15, 2003 | 10:12 AM
Boltz's Avatar
Default Re: Today's SC61 baseline dyno numbers (exsleeper)
judging by your username i thought you would be sporting a sohc and i got excited. oh well, have fun with it!
Old Dec 15, 2003 | 10:42 AM
InTeGrA B18b1's Avatar
Default Re: Today's SC61 baseline dyno numbers (Bolts(eastermaro))
with an sc61 would it keep making power to redline?
Old Dec 15, 2003 | 11:38 AM
Javier23's Avatar
Default Re: Today's baseline dyno numbers (BlueSi2k)
looked like 11's and 10's on boost
