Compressor wheel ?
Old Feb 10, 2006 | 09:57 AM
Got_soy's Avatar
Default Compressor wheel ?
would the pvc system make the compressor wheel gunked up on an oem turbo car such as an audi or saab? Would that be a bad seal?
Old Feb 10, 2006 | 11:44 AM
Finland's Avatar
Default Re: Compressor wheel ? (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy &raquo;</TD></TR><TR><TD CLASS="quote">would the pvc system make the compressor wheel gunked up on an oem turbo car such as an audi or saab? Would that be a bad seal? </TD></TR></TABLE>
Yes, almost all cars that have an OEM intake tube will have a breather hose running from the cam cover to the air intake...and that would mean that on an OEM turbo car, oil vapors would end up on the compressor wheel. You could put a baffled catch can in the middle to catch some of the oil. If there's a lot of oil on the compressor wheel, it's probably a sign of poor compression and blow by. The turbo itself could also be leaking oil, but the compressor is pressurized most of the time, so chances are you would notice the turbo oil leak on the turbine side.
Old Feb 10, 2006 | 12:39 PM
Got_soy's Avatar
Default Re: Compressor wheel ? (Mr. Helsinki)
cool i was asking because of a turbo i got off of a saab
Old Feb 10, 2006 | 03:08 PM
marmo's Avatar
that can cause oil buildup on the compressor wheel for sure....but the seals are probably leaking too.
zerovandez
May 1, 2016 05:10 AM
ryguy2588
Jun 9, 2011 02:27 PM
freakie
Mar 4, 2007 12:33 AM
.RTErnie
Jul 9, 2005 05:58 PM
TeStUdO
Feb 25, 2003 08:42 AM
