Compressor surge after intake install
Old May 15, 2013 | 08:20 AM
$amGD3's Avatar
Swaggylicious
Default Compressor surge after intake install
After running open turbo for the last two years, I finally got a radiator/fan setup that will let me have enough room to install a filter. Nothing fancy, just a 45deg silicone elbow, a short piece of piping, and a K&N.
Before I installed the lil guy, I would never hear any compressor surge, just my Greddy Type-S doin it's thang. But then the intake came on, and now I would hear the BOV AND surging.
I'm trying to think what factors would've changed that lead me to this?
Air velocity is considerably less now that there is a filter thus I have to adjust the BOV to a softer setting?? And yes I have adjusted it softer but it's still doing it (the surge). How soft should I go? and more importantly, why does this call for a change because of a simple filter?
BTW I can only hear the surge if I go WOT
EDIT: Video
Old May 15, 2013 | 12:23 PM
TheShodan's Avatar
Moderator
Default Re: Compressor surge after intake install
Video to show example please.
Old May 15, 2013 | 12:27 PM
sanman000719's Avatar
your demand your calling for has changed at wot man.
you are now not supplying that amount of air due to restricting it with the filter.
Old May 15, 2013 | 12:31 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Did you do any math to figure out if the filter you chose would flow adequately for your setup? I assume not.
Old May 15, 2013 | 12:55 PM
$amGD3's Avatar
Swaggylicious
I honestly just shopped around for a filter that would fit. This particular one has a pretty unique dimension, angled neck and super slim up top and in general.
How would i even calculate the flow?
Old May 15, 2013 | 12:56 PM
$amGD3's Avatar
Swaggylicious
This is what I originally had assumed, but then I've had some people tell me that I have always had a compressor surge but now that I have a filter on there, I can hear it
I don't know who to believe
$amGD3's Avatar
Swaggylicious
Coming right up!
Old May 15, 2013 | 06:15 PM
Muckman's Avatar
Moderator in Chief
I dont hear any surge!
LOL I laughed when I saw that filter too.
Call or email K&N with the part number, they can calculate the surface area and give you a CFM rating. Its probably OK unless youre making over 300hp.
Old May 16, 2013 | 08:29 AM
DO IT ON ALL FOURS
All you need to do is... SEARCH -
http://www.knfilters.com/filter_facts.htmll
Then find out your turbo flow (most likely LBS per Min) and if needed convert to CFM for your guesstament (because obviously it isn't a direct conversion) and you have your info. It is really simple.
Old May 16, 2013 | 08:31 AM
LightningTeg's Avatar
Community Builder
I'm running a filter with about 2/3's the surface area of that one and taking it off on the dyno netting no change in power at ~500whp.
Old May 16, 2013 | 09:07 AM
TheShodan's Avatar
Moderator
I'm not hearing anything out of the ordinary here, perhaps something slightly reverted, but nothing huge. Surge is very apparent.. He's shifting a bit fast. i was hoping for being in gear going into boost gradually into full pressure, then shifting to another gear. Not power pulls.
Either way, a filter won't cause the surge, but it may be the valve is tightened down too much for the boost pressure being run.
Old May 17, 2013 | 05:21 AM
$amGD3's Avatar
Swaggylicious
Took another vid, I don't know if you can hear the difference in the BOV sound when it's partially in boost and then at a higher boost level
Old May 17, 2013 | 05:34 AM
Community Builder
I dont hear anything wrong...
dartonh22
Feb 16, 2008 09:04 AM
boostdummy
May 5, 2006 06:24 PM
RedTegLS
Dec 18, 2003 07:35 AM
sleepyhamsterlx
Jul 14, 2003 09:56 PM
