Compressor surge
Old Aug 30, 2013 | 10:18 PM
TravisBiggie's Avatar
Default Compressor surge
Mods in sig.
I have a greddy type rs bov. Ive had compressor surge with the BOV on its softest setting, and the hardest setting. After some research, I was told to remove the small spring inside the bov. I did. Still compressor surge with the BOV on its soft setting.
The BOV is right above the transmission, close to the throttle body.
Any tips?
Also, for some reason, my radiator fan stopped working, again. I just replaced the switch which seemed to fix the issue, randomly driving around, my coolant level spikes. I do have a leak in my radiator, so I'm not sure if the lack of coolant would do this.
Any help will be appreciated.
Old Aug 30, 2013 | 10:47 PM
turbohatch96y7's Avatar
Default Re: Compressor surge
If you have a leak you have air in the radiator system. Those pockets of air throw off the fan switch thermo sensor. Fix the leak.
Post a vid of the compressor surge. Could be a leak in the charge piping. Double check every connection and intercooler.
Old Aug 30, 2013 | 10:57 PM
thanks for the info. Tomorrow I will get a video. I have a feeling I have a leak somewhere.. I'll investigate.
Old Aug 31, 2013 | 01:42 AM
exact same, muuuuuch louder under high boost.
How could a small boost leak cause compressor surge?
Old Aug 31, 2013 | 03:46 AM
m4xwellmurd3r's Avatar
is this the sound youre talking about? because what you posted is flutter, not compressor surge. surge happens when the turbo is trying to push more boost than it can handle at a certian speed or something like that.
Posted from Honda-tech.com App for Android
Old Aug 31, 2013 | 04:01 AM
compressors stall, not flutter is what I mean.
compressor stall happens when the turbo is making more pressure on the compressor side than on the exhaust side (lifting off with a stuck bov)
surge happens at wot usually, and is caused by the turbo pushing more boost than the engine can use for a given rpm. so the turbo starts making a chirping fluttering noise as the pressure builds up in the intake, exceeds the exhaust pressure, surges and tries to reverse direction (the loud chirping noises) then intake pressure drops, exhaust pressure then becomes greater than intake, builds up too far, etc etc. its an oscillating cycle.
maybe your bov is damaged and not venting properly.
Old Aug 31, 2013 | 05:19 AM
Turbo-LS's Avatar
Where is your vacuum line going to from the bov ? Is it a real greddy? If your vacuum line is hooked to a Tee with another line for the BOV ditch that and give it a dedicated line from the manifold
Old Aug 31, 2013 | 02:15 PM
its a real greddy. Its directly connected to the intake manifold, no T
Old Aug 31, 2013 | 04:04 PM
Don't the greddy's sound like that?
Seems normal never owned a greddy though
Old Aug 31, 2013 | 04:29 PM
dueyx99's Avatar
you say you have the soft spring installed and the bov is on its softest setting? now does that mean you backed off the adj stud all the way out? if thats the case, like you said, i'd check for a leak in the line somewhere feeding the bov
Old Aug 31, 2013 | 04:53 PM
Turbo-LS's Avatar
If its all the way soft it will flutter too
Old Aug 31, 2013 | 06:39 PM
viper_boy403's Avatar
that sounds like its fluttering because it's TOO loose. Pic of how it's installed? How does it react at full boost?
Old Aug 31, 2013 | 11:00 PM
The flutter doesn't bother me, but under full boost, its nasty compressor surge. I'm going to replace the intake manifold vacuum line. I'm also going to inspect the diaphragm since these bov's are notorious for ******* up.
Heres actual video. I would have stayed neck n neck if I didn't bounce off my rev limiter (first time going WOT with this tune) And yes, that is coolant on my windshield. At first I completely forgot about the leak in my radiator, I thought it was oil
So, this seems like I have "flutter surge", does anyone agree?
Old Sep 1, 2013 | 12:40 AM
yungkhmer's Avatar
Turbo B18B1 Civic vs 06 600cc F4i - YouTube
ILLEGAL to cross double white lines..
LOLLL jk i do that shiiit all the time anyways.
Old Sep 1, 2013 | 04:44 AM
Turbo-LS's Avatar
Just sounds like a greedy bov to me. Maybe a little loose on the setting but about normal sound
Old Sep 1, 2013 | 05:11 AM
TheShodan's Avatar
Moderator
Yep. Completely normal, though a bit on the loose side. Its not compressor surge. Those diaphrams rarely died except on the fake ones. Putting the second spring in, make sure the line to the IM isn't collapsing, otherwise, its fine.
Old Sep 1, 2013 | 06:57 PM
Thanks guys.
teg_95
Jun 3, 2010 04:20 PM
JO
Sep 7, 2004 10:56 AM
turtle-eg
Apr 26, 2004 05:14 PM
luvboost
Dec 27, 2002 11:52 PM
bretx0r
Aug 17, 2002 05:34 AM
