Hesitation/Misfire problem, went thru 3 ICMs, 99 Boosted B20 whats going on?!
Old 04-30-2006, 10:18 PM
blazin99si's Avatar
Default Hesitation/Misfire problem, went thru 3 ICMs, 99 Boosted B20 whats going on?!
I was spraying for almost a year with a Zex Dry 55 & 75 shot when all of a sudden I was having a really bad misfire/hesitation problem when I would start spraying around 3500-4500 rpm at full throttle. Ignition consisted of Iridium plugs, MSD wires, Cap and Exteral Coil.This would only happen under spray, NA it would pull up to 7k with no problems-part throttle and WOT. My RPM tach stopped working as well and was told when that happens its the ICM. Switched out the ICM everything was fine for a few days but the tach went dead again same misfire sh*t, ocasionally would get check engine light, code 43 "Fuel System." Installed a Walbro 255 LPH pump, B&M FPR, RC 310s but to no avail. Ditched the nitrous and went boost. Crome Pro on 8.7 psi, new NGK BKR7E's gapped to .26, DSM 450s with inline 10watt, 10 Ohm resistors and at 4500 and up same bad misfire/hesitation, no check engine light though. Took the cap off and found the screw that holds the rotor in came loose and caused havoc inside the dizzy, broke all the teath on the inside of the dizzy. Replaced the dizzy with a used one of a buddies car and it ran like a champ no problems, RPM tach all good as well for a few days. Tach went dead again and hesitation returned but not as bad as before. Both old and used dizzy were OBD2. Engine wire harness is OBD2 of course. Replaced the used dizzy with a brand new one (OBD2), ditched the MSD stuff and put in some stock used plug wires I had. Tach back again, no hesitation everything good again for a few days. Now slight hesitation is back sporadically under WOT 4500 to about 5700-6000 and tach is dead again. What could be frying the ICMs this makes 3!! WTF any help will be greatly appreciated. No check engine lights.
Someone suggested to check the tps but I dont know how with my 6$ voltometer
99 B20, p75 ecu, obd2-obd1 harness
Sorry for the book report
Old 05-01-2006, 02:59 AM
drintegra's Avatar
Default Re: Hesitation/Misfire problem, went thru 3 ICMs, 99 Boosted B20 whats going on?! (blazin99si)
Bump for a fix
Old 05-01-2006, 07:48 AM
drintegra's Avatar
Details here
https://honda-tech.com/zerothread/1598843
Old 05-01-2006, 09:42 AM
drintegra's Avatar
Default Re: Hesitation/Misfire problem, went thru 3 ICMs, 99 Boosted B20 whats going on?! (drintegra)
Bump for some help
Old 05-01-2006, 02:50 PM
drintegra's Avatar
Old 05-01-2006, 11:50 PM
blazin99si's Avatar
Damn no one??
Old 05-02-2006, 06:35 AM
drintegra's Avatar
Old 05-02-2006, 07:19 AM
something different
redzcstandardhatch's Avatar
try putting a small ground wire to one of you distributor bolts.
worth a shot.
my dad used this fix ona few GM cars that kept killing ignition control modules, and it worked every time. maybe there is something to it. i have one on my civic now, and its isnt hurting anything.
Old 05-02-2006, 10:07 AM
drintegra's Avatar
Default Re: (redzcstandardhatch)
Will try definately need to do something as we just tried a totally new distributor and it got fried within a few days. Don't know, But I have a feeling it has to do with the revs and load. Thanks
Old 05-02-2006, 03:00 PM
WHITE DEATH's Avatar
Default Re: (drintegra)
Holy hell, good luck with getting it fixed. If it were my car I would have got so frustrated. By now I would have just set it on fire.
Old 05-02-2006, 06:36 PM
drintegra's Avatar
Default Re: (jdmtegra666)
^^^^ He is almost to that point.
Old 05-05-2006, 06:58 AM
drintegra's Avatar
Fixed the problem ended up being the sprak plugs in combination with the ICM. Apparently one of the sprak plugs had cracked at the porcelain part. After replacing the ICM and sparkplugs the car runs fine. Hopefully it will stay
WIll post some full throttle pulls once I get a chance.
NotoriousEK
09-18-2009 04:14 PM
ttk3
16
04-23-2007 11:21 AM
SilverCivic96
03-01-2007 05:07 PM
blazin99si
05-01-2006 11:51 PM
probot757
03-23-2006 05:54 PM
Quick Reply: Hesitation/Misfire problem, went thru 3 ICMs, 99 Boosted B20 whats going on?!
