compression test results 4 boosted b20/vtec tell me what you think .
i just did a compression check to see check out things and the results were
4 3 2 1
180 175 175 175
keep in mind this is a 9:1 block with a gsr head . which i believe would get me around a 9.3:1 total compression . not sure though
let me know what you think about the #'s
4 3 2 1
180 175 175 175
Re: compression test results 4 boosted b20/vtec tell me what you think . (B20TDC2)
if its a jdm b20 then its 8:8:1 comp, the usa b20 is 9:2:1 and with a gsr head its the same, good numbers tho.
sounds about right........my 9:1 B20 pumps out about the same........
