compression test (part 2)
Old May 11, 2004 | 11:58 AM
slamedturtle's Avatar
Default compression test (part 2)
okay people of honda tech here it goes. i have been saving up to buy the endyn head and thought that it would be a good ideal to check the compression since its been about 2 or 3 weeks since the last time ive done it and i found that i had a bent valve from doing a leak down test also. before it was this from left to right. 120, 170, 170, 170. or something in that manner. since then i have added some valve cleaner made by cheveron......................
I did this recent one on sunday and it was the strangest ****. 180 on all four cylinders. i did like 3 times and the same each time. What do you all think, carbon build up on the valves. and do you all think it is still a good idea to pull the head and check the valves anyways. you know how that **** is though, dont fix it if its not broken. thanks guys. just need some more opinions.
Old May 12, 2004 | 03:00 PM
quikB18B's Avatar
Default Re: compression test (slamedturtle)
Yeah i was there with Anthony through all the compression test, It was low 120 like he said, and it wasn't running to par, He added some type of system cleaner and it now reads 180 Anyone have an explanation?
Bump for an answer.
The leak down test showed that it was exhuast valves and before he could pull the head all is good now.
Old May 12, 2004 | 03:58 PM
b18bturbo's Avatar
Default Re: compression test (quikB18B)
mostly likely carbon buildup most of the cleaners on the market are there to remove carbon deposit and clean the intake and exhaust valves as well as the piston domes
Old May 12, 2004 | 09:18 PM
Default Re: compression test (b18bturbo)
yeah im glad this **** is fine though. the motor was just built by golden eagle and spent an *** load of $$$$$$$$$$$$$$$.
JBirch_97Prelude
Mar 9, 2021 03:01 PM
The Dirty EJ1
Jun 30, 2008 12:37 AM
leeminho86
May 18, 2006 08:14 AM
RGoose18
May 21, 2004 10:13 AM
Goldfingiz
Dec 13, 2002 10:30 PM
