Stripped head bolts
Old May 28, 2003 | 02:45 PM
1bar's Avatar
Default Stripped head bolts
As stated above, what are my options, whats the name of that one snap on tool, im not gonna mention who stripped the bolt (hybridvteceg) lol jk i thought i ask some question until we give it another shot tomorrow.
jake
Old May 28, 2003 | 03:20 PM
ninesecrx's Avatar
Default Re: Stripped head bolts (1bar)
easy out or a bolt extractor...
Old May 28, 2003 | 03:21 PM
1bar's Avatar
Default Re: Stripped head bolts (ninesecrx)
How much do bolt extractors usually run?
Old May 28, 2003 | 03:26 PM
boosted_dc2's Avatar
if your taliking about the studs that hold the head on then an easy out wont do a thing for you. your probably going to have to drill it out!!!! have fun let us know how it turns out...
Old May 28, 2003 | 03:53 PM
Jared's Avatar
Default Re: Stripped head bolts (hooked_up_gsr)
Did it break on removal or on installation? And does it spin and not move or did it just break off flush?
Old May 28, 2003 | 03:59 PM
1bar's Avatar
Default Re: Stripped head bolts (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">Did it break on removal or on installation? And does it spin and not move or did it just break off flush?</TD></TR></TABLE>
We were trying to take the head off, the head of the bolt is still there but it is rounded off. We tried gettin a 13mm on there but no dice. Does anyone have a link to the Snap on Bolt extractor.
Old May 28, 2003 | 04:02 PM
1bar's Avatar
He started another thread about it...i told u he did it lol
https://honda-tech.com/zerothread?id=518780
Old May 28, 2003 | 04:07 PM
dfoxengr's Avatar
haha
not my fault u were using crappy 12 points.
Old May 28, 2003 | 04:21 PM
1bar's Avatar
Default Re: Stripped head bolts (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">haha
not my fault u were using crappy 12 points. </TD></TR></TABLE>
haha ur still the one who first stripped it not meee
Old May 28, 2003 | 04:27 PM
dfoxengr's Avatar
die ****, ive done enough for you with this project. =3 deez
Old May 28, 2003 | 04:42 PM
1bar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">die ****, ive done enough for you with this project. =3 deez</TD></TR></TABLE>
i was even peer pressured to buy the kit....u *****
Old May 28, 2003 | 04:45 PM
dfoxengr's Avatar
also i slaved away on that install for you hahaha. but hey what are best friends for huh
Old May 28, 2003 | 05:30 PM
Jared's Avatar
This is what you need. I have a set, they are the ****, hammer them on, then use a big impact to remove.
http://buy.snapon.com/catalog/...talog
Old May 28, 2003 | 05:35 PM
dfoxengr's Avatar
that link doesnt work
Old May 28, 2003 | 05:38 PM
dfoxengr's Avatar
like these?
from snap-on, i thinkwe have some at my shop. sweet
Old May 28, 2003 | 05:52 PM
Mikeyslude's Avatar
my guess is you will have to drill it out.
Old May 28, 2003 | 05:53 PM
speedworks's Avatar
drill a hole through the center of the bolt until you are about to the bottom of the head. start with an eighth inch bit and work your way up to about 3\8 inch. then drive an old socket over the bolt and twist slowly. this will shear the head off. slide the head off the block. the rest that is left will usually screw out with your fingers.
also put shop towels around the head of the bolt while drilling to catch the metal shavings.
Old May 28, 2003 | 06:01 PM
dfoxengr's Avatar
Default Re: Stripped head bolts (speedworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">drill a hole through the center of the bolt until you are about to the bottom of the head. start with an eighth inch bit and work your way up to about 3\8 inch. then drive an old socket over the bolt and twist slowly. this will shear the head off. slide the head off the block. the rest that is left will usually screw out with your fingers.
also put shop towels around the head of the bolt while drilling to catch the metal shavings. </TD></TR></TABLE>this is my last resort option, lol. after we see if we have the snapon tools
Old May 28, 2003 | 06:06 PM
Jared's Avatar
That link works fine for me. Here is a link to the pic in the ad.
Old May 28, 2003 | 06:07 PM
hybridreams's Avatar
Craftsman has something similar...looks exactly like that actually. Saw it at Sears the other day.
Old May 28, 2003 | 06:11 PM
speedworks's Avatar
Default Re: Stripped head bolts (hybridreams)
you can drill it out in about 10 minutes
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">you can drill it out in about 10 minutes</TD></TR></TABLE>
then will it easily unscrew when the head is off?
Old May 28, 2003 | 06:13 PM
Phoenix GSR's Avatar
those met-wrench sets that sears sells have always worked good for me.. they grab the nut on the flat part.. I think a set is like $30.. but it has been a while since I bought them..
Old May 28, 2003 | 06:17 PM
speedworks's Avatar
Default Re: Stripped head bolts (Phoenix GSR)
the one i did i screwed all three out with my fingers. it was a piece of cake
Old May 28, 2003 | 06:46 PM
DR. ON POINT's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">the one i did i screwed all three out with my fingers. it was a piece of cake</TD></TR></TABLE>
another idea..... extremely shady by the way is get some JB weld and JB weld a socket to it..... than remove
Loves JB WELD
