compression ration
Old Nov 2, 2001 | 07:49 AM
BLaCKWiDoWSi's Avatar
Default compression ration
Which JE piston is better for a turbo si.....the one with 9:1 compression ratio or 11:1 compression ratio b\c i'm planning to get new pistons and connecting rods but i need some advice.
Old Nov 2, 2001 | 08:04 AM
2fastGSR's Avatar
King of the One Liners
Default Re: compression ration (BLaCKWiDoWSi)
9:1, 11:1 is too high for boost.
Old Nov 2, 2001 | 09:01 AM
bigTom's Avatar
Default Re: compression ration (2fastGSR)
i tend to like the 11:1... but only if u have means the tune it correctly
Old Nov 2, 2001 | 09:07 AM
Default Re: compression ration (ek9t)
So for a turbocharged si with t3/t4 turbonetics it's better to use 9:1 compression??
How would the 11:1 piston help??
Old Nov 2, 2001 | 09:19 AM
BoostinDC2's Avatar
why not 10:1?
Old Nov 2, 2001 | 01:51 PM
Project_Integra's Avatar
New User
How many pounds of boost are you planning to run? You will have to be extremely careful with 11:1 as opposed to 9:1. You can do 9.5:1 safely with moderate amounts of boost.
No matter what though, <U>tuning is everything</U>.
Old Nov 2, 2001 | 03:12 PM
bigTom's Avatar
Default Re: compression ration (Project_Integra)
10:1 is poretty safe with today's technology IF the person putting it together knows what they are doing... too many people nowadays think they know what they are doing when they really dont... anything higher than 10:1 imo does really need a standalone... 9:1 is pointless nowadays... its too low for the street... at least go a couple tenths higher... true... with 11:1 or any higher u have to be really careful as u have much less room for any error... meaning if its not tuned right it will go boom! but then again so will any setup not tuned right... but u have more "play" in tuning lower comp
peakboosth22
Jun 20, 2006 08:55 AM
jdm2teg
Dec 14, 2005 01:41 PM
oilguzzler
Nov 17, 2005 07:52 PM
Quade
Apr 5, 2005 03:12 PM
immortal
Nov 6, 2001 08:05 AM
