Compression Ratio Help
Old Dec 6, 2001 | 08:58 PM
MisterB's Avatar
Default Compression Ratio Help
I am getting pistons (probably Arias) made for my f22b turbo motor and i need some advice on what to go on the CR.i was told stock is 8.8:1 so should i keep it the same drop it to 8.5:1 or raise it a bit to 9:1 for better off boost power. the motor is daily driven.
[Modified by cl4show, 6:57 AM 12/7/2001]
Old Dec 7, 2001 | 12:06 PM
MisterB's Avatar
Default Re: Compression Ratio Help (cl4show)
?????????? any help would be great???????
Old Dec 7, 2001 | 12:32 PM
forcefed's Avatar
you will be fine with 9.1:1. though that moter is prone to detonation in high rpm, under boost. if you are getting pistons then i assume you want to go big with the boost if you want that you will also have to get injectors, and piggy back computers, or standalone and goooood tuning. won't be cheap.
I knew this gut with 447 whp out of his f22. he was boosting 22lb and revving to 9000 pretty good for a sohc huh needless to say this is not a street motor
for a daily driver 9.1:1 will be fine, and you could probably get 10psi on it daily
with some fuel enrichment but it is an open deck so don't push it to hard
Old Dec 7, 2001 | 10:58 PM
type autox's Avatar
New User
Go with the 9.0:1. More torque, better boost response.
Are you the guy with the blue CL?
Old Dec 8, 2001 | 02:25 PM
MisterB's Avatar
Default Re: Compression Ratio Help (type autox)
Ya thats me with the blue CL but its out of order and has been for a while do i know you?
Old Dec 8, 2001 | 10:11 PM
type autox's Avatar
New User
I go to mira costa college, I have seen your car around. Maybe you had seen my car; dark blue integra ls with enkis. I have rotas on now. If I ever see you around, my name is Matt. Later.
Old Dec 9, 2001 | 03:30 PM
fowler!'s Avatar
Heh, I park by you all the time. Silver Ek, black Rotas. Funny that you post on this board.
Old Dec 9, 2001 | 05:56 PM
BlueShadow's Avatar
Default Re: Compression Ratio Help (fowler)
well as opposed to what the other guys said, if you're upgrading the entire bottom end anyway why not go with the lower compression pistons? you'll be able to run more boost and get more power. 8.5:1, your off boost condition will probably be crappy though less power/torque. with a higher compression though you will be more likely to detonate unless you use high octane gas.
I would look into some more before deciding.
Old Dec 9, 2001 | 06:34 PM
Tomakit's Avatar
Default Re: Compression Ratio Help (BlueShadow)
keep in mind that 1 point in compression, either way (up or down) is only good for 3-4% hp.
Tom
Old Dec 9, 2001 | 10:05 PM
type autox's Avatar
New User
No no, thats another guy! I think he has a b16 swap. He does have an N1, loud as hell. I can hear him pulling away while I am in class. I have a blue Integra with the SPW388 ripoffs. He has mugen ripoffs.
By the way, my motor has 10.5:1 compression and I am gonna be bosting in the next few months. Its all about how you set it up.
Old Dec 9, 2001 | 11:31 PM
fowler!'s Avatar
lol..no, I'm the guy with the loud *** muffler. It's okay...it bothers me too.
Old Dec 14, 2001 | 03:06 PM
MisterB's Avatar
8.5:1 sounds good but what if for some reason i decide to take off the turbo then how am i going to be able to raise the compression without swapin the pistons for stocks
Old Dec 14, 2001 | 03:25 PM
01geeser's Avatar
New User
just leave it stock c/r then itll be fine.the stock c/r isnt that high anyways.
awaludinyuli
Feb 10, 2014 08:02 PM
EJ8 GSR-T
Oct 7, 2008 04:17 PM
92civtegra
Aug 15, 2007 08:26 PM
deemack79
Feb 14, 2005 05:33 PM
hahaitzsteven
Jan 9, 2005 06:09 PM
