What compression do you run, In you built engine?
Old Apr 23, 2004 | 10:25 AM
PGT Driver's Avatar
Default What compression do you run, In you built engine?
I am trying to get a feel for what compression you guys run in you cars. I dont care about stock so much, but more less what you run with a built motor and how many PSI your running.
Old Apr 23, 2004 | 11:04 AM
B18 CYA's Avatar
Default Re: What compression do you run, In you built engine? (PGT Driver)
JE 9:1 81mm Pistons, Eagle H Beam Rods, SRP Blockguard. Planning to run 12-15 psi...
Old Apr 23, 2004 | 11:24 AM
tygsr's Avatar
9:5:1..endyn rollerwaves..
Old Apr 23, 2004 | 11:33 AM
seen4ever's Avatar
Default Re: What compression do you run, In you built engine? (tygsr)
9.2:1 Endyn Rollerwaves, 81.5mm, b18c1.
Old Apr 23, 2004 | 12:00 PM
kpt4321's Avatar
Search for compression ratio there are a ton of big long threads with some good information.
Old Apr 23, 2004 | 12:23 PM
SupaTeg's Avatar
9.1 buddy
Old Apr 23, 2004 | 12:27 PM
Nextelbuddy's Avatar
Default Re: What compression do you run, In you built engine? (SupaTeg)
9:1 je but i wish i would have went with 10:1 je pistons... wold be easier to make more power with less boost.
Old Apr 23, 2004 | 04:43 PM
PGT Driver's Avatar
i dont drive a honda but i am just curoious as to what works for you guys, i mean hell if you guys can why cant i. I want to run maybe 10:1 or atleast 9.5:1
Old Apr 23, 2004 | 04:51 PM
94gsr4dr's Avatar
Default Re: (PGT Driver)
9:8:1 cp's
Boost isn't important; its the power you want to make
Old Apr 23, 2004 | 04:59 PM
PGT Driver's Avatar
Default Re: (94gsr4dr)
boost is important but i want higher compression too so i can make more power
Old Apr 23, 2004 | 05:00 PM
g2turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">9:8:1 cp's
Boost isn't important; its the power you want to make</TD></TR></TABLE>
same here 81mm CP 9.8:1.
Old Apr 23, 2004 | 05:05 PM
94gsr4dr's Avatar
Default Re: (g2turbo)
i got 81.5's, but close none the less. When i plan out a motor i set a horsepower goal not a pressure goal.
Old Apr 23, 2004 | 05:32 PM
11psiTurboSI's Avatar
b16a2 stock bore (81mm) JE pistons-8.8:1cr
Old Apr 23, 2004 | 05:38 PM
kpt4321's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PGT Driver &raquo;</TD></TR><TR><TD CLASS="quote">i want higher compression too so i can make more power</TD></TR></TABLE>
In the end, you will make more power with lower compression and higher boost, as long as you are not limited by turbo sizing.
Old Apr 23, 2004 | 05:41 PM
mildly.interesting's Avatar
8:5.1 Arias, pushing in the neighborhood of 22-25 lbs daily.....
represent....
Old Apr 23, 2004 | 05:45 PM
USDM 4G VTEC's Avatar
76mm SRP (JE) 9.0:1 forged pistons on Eagle H beam rods
hoping that 10-12 will not even tickle it
Old Apr 23, 2004 | 06:44 PM
espanol's Avatar
je 9:1 stock bore, 14-21 psi on any given day.
Old Apr 23, 2004 | 06:51 PM
illi Adik's Avatar
9:8:1 JE's
vtec.dc2's Avatar
10:1.. 260whp right now, i don't plan on making more than 300whp.. possibly 325whp
Old Apr 23, 2004 | 07:08 PM
queez's Avatar
Default Re: What compression do you run, In you built engine? (vtec.dc2)
9.4:1 . cp pistons 84mm bore on b16a2
Old Apr 23, 2004 | 07:22 PM
r1racer's Avatar
10:1 JE Pistons with Crower Rods
Old Apr 24, 2004 | 05:30 AM
Soon_2b_evil's Avatar
Default Re: (r1racer)
10.5 Wiseco pistons with a 84.5mm bore. ALmost done.
Old Apr 24, 2004 | 09:22 AM
RAWB's Avatar
9:8:1 CP's/81.5mm
*GSR block w/B16 head = 9:6:1
Old Apr 24, 2004 | 09:46 AM
Rod.'s Avatar
Default Re: What compression do you run, In you built engine? (RAWB)
9:1 cp pistons
Old Apr 24, 2004 | 09:56 AM
g2turbo's Avatar
Default Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 &raquo;</TD></TR><TR><TD CLASS="quote">
3 bar? If you want to feel safe... sure run 8:1 compression and 40 lbs of boost. Im limited to a 3 bar system and feel no need to run over 28 lbs... which will most likely make my whp goal with my setup. Im also not worried about making 400 or more on pump gas. 10:1
