Compression Questions
Old Feb 23, 2003 | 07:20 PM
Jspd's Avatar
Default Compression Questions
hey guys. i have a 95 LS and i compression checked it today. i need to know if my numbers are still okay for boost?! here they go.
CYL. 1: 180
CYL. 2: 155
CYL. 3: 160
CYL. 4: 175
the honda manual says youre okay if its b/w 135 and 200. with no more than a variance of 28 b/w the neighboring cylinders. someone who knows there stuff on LSs and compression prior to a turbo installation please help!!!! thanks for your time.
[Modified by Jspd, 10:21 PM 2/23/2003]
Old Feb 23, 2003 | 07:23 PM
boostedsol's Avatar
Default Re: Compression Questions (Jspd)
hmmm...if I remember correctly, I think for an ls 150 accross is about right. your numbers look kinda high and inconsistant.
Old Feb 23, 2003 | 07:25 PM
Jspd's Avatar
Default Re: Compression Questions (boostedsol)
yeah i know. all the plugs were pulled and the injectors were still connected. i only did it once. the book said 200 was perfect and below 135 was too low. i just dont know if its still okay to boost?!
hey i just remebered i DID NOT have my foot on the gas at WOT. just on the clutch while i cranked it over.
[Modified by Jspd, 10:28 PM 2/23/2003]
[Modified by Jspd, 10:45 PM 2/23/2003]
Old Feb 23, 2003 | 09:01 PM
ski_rebel_3's Avatar
Hey John… those numbers seem real inconsistent for a non-built motor. Did you do a leak down test as well or just a compression test? If you didn’t do both then do it! If I were you I would run the car up to Stoney at VSV and have him do it for you just for peace of mind. It will only take him about 10 minutes and you will know 100% for sure what’s up.
Old Feb 24, 2003 | 07:01 PM
TurboSiCoupe's Avatar
i only did it once........hey i just remebered i DID NOT have my foot on the gas at WOT. just on the clutch while i cranked it over.
Two strikes rite there, hehe, j/p. You should crank the car 3 or 4 times for each cylinder, and make sure the gas pedal is held down to open up the throttle plate. Good luck.
vinceiscoo
Jan 8, 2010 09:53 PM
xonn
Apr 10, 2003 10:55 AM
Jspd
Mar 17, 2003 11:12 PM
94TealGSR
Jan 5, 2003 08:53 PM
