compression question
Old Apr 25, 2004 | 04:42 PM
1gen crxer's Avatar
Default compression question
ok i am planing on getting an 88-91 crx si, i am gunna take the b16a out of my 85 crx si. I plan on going turbo possible run 10psi daily, most importantly i want at least 230 whp, so i ask you this if i get a t3/t4 turbo kit with an iontercooler what compression pistons shoul di get, i am looking into je pistions with eagle rods, ctr cams, titanium valves and eibatch valve springs and 450cc injectors what else to make this possible and most importantly what compression to go with i was thinking 8.5:1 or even 8:1
Old Apr 25, 2004 | 04:49 PM
PrecisionH23a's Avatar
Default Re: compression question (1gen crxer)
8.0:1 is way too low. 9.0:1 is a greaty happy medium, but a lot of guys have been using 10:1 just fine with good tuning.
Keep in mind, the lower your compression the lower your power yield will be and your spool up times will also decrease. With a decent trim turbo (57 comp trim .48 a/r t3) you should easily be able to hit 250whp at 10psi with a 9.0:1 piston. And I'm sure you know that EMS is very important as well so I will spare you the lecture.
Old Apr 25, 2004 | 04:52 PM
1gen crxer's Avatar
no no please tell im new to this the only thing i have done is droped a b16a in my 85 nothign else i wanna learn so tell what is ems
Old Apr 25, 2004 | 04:56 PM
Default Re: (1gen crxer)
Engine Management System
It allows you to change your fuel curves and ignition tables.
http://www.hondata.com
http://www.aempower.com
https://honda-tech.com/zerothread?id=694581
Or you can always run an s-afc hack
https://honda-tech.com/zerothread?id=531705
The AFC hack will not allow you to change your ignition tables, but you can change your fuel settings on this set-up.
I cannot stress how important tuning is. Search this site for any other questions, 99/100 of them have already been covered, answered, and covered 10 more times.
Old Apr 26, 2004 | 04:11 PM
1gen crxer's Avatar
ok so say i get the s100 boost from hondata would that be good for a b16a ctr cams je 9:1 compression and eagle rods, what do you think is the max boost i will be able to run safly for daily driving, this is with p&p head and honed block
hellcivic1996
Jan 22, 2007 05:58 PM
jdmcivic1999
Aug 19, 2005 06:35 PM
GDM Z28
Apr 26, 2004 06:09 AM
ucantcatchmefoo
Feb 24, 2004 09:18 PM
symba
Jul 23, 2002 09:10 AM
