Compression problem.
I plan on boosting my ZC so I did a compression test.
cyl#1-180
cyl#2-155
cyl#3-175
cyl#4-180
ok, #2 is low, so I did a leak down test to see where i was losing the compression and it seemed fine with 120 psi going into it, no more hiss than any of the other cylinders and I couldnt tell at all where it would be leaking. Anyone have any ideas where I could be losing the compression or another way I could check to find out? thanks.
cyl#1-180
cyl#2-155
cyl#3-175
cyl#4-180
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Albes »</TD></TR><TR><TD CLASS="quote">I plan on boosting my ZC so I did a compression test.
cyl#1-180
cyl#2-155
cyl#3-175
cyl#4-180
ok, #2 is low, so I did a leak down test to see where i was losing the compression and it seemed fine with 120 psi going into it, no more hiss than any of the other cylinders and I couldnt tell at all where it would be leaking. Anyone have any ideas where I could be losing the compression or another way I could check to find out? thanks.</TD></TR></TABLE>im not sure of a better way to test the compression. I know #2 is low...but it's still in tolerance (all cylinder's need to be within 20% of each other)
cyl#1-180
cyl#2-155
cyl#3-175
cyl#4-180
Nah its not the headgasket, i would lead more to a valve or just waekening rings.
**** i have been running 10psi on a stock b16 with under 120psi in all cylinders and i am fine......... for now
I checked all the valves to make sure that it wasnt an adjustment that was causing a leak, they were all adjusted correctly, so its either a valve not seating properly or yeah weakening rings. oh well, boost will bring that compression up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Albes »</TD></TR><TR><TD CLASS="quote">I checked all the valves to make sure that it wasnt an adjustment that was causing a leak, they were all adjusted correctly, so its either a valve not seating properly or yeah weakening rings. oh well, boost will bring that compression up.
boost it till it pops, then find out why it had low compression!
</TD></TR></TABLE>boost it till it pops, then find out why it had low compression!
cyl#1-180
cyl#2-155
cyl#3-175
cyl#4-180
What % was #2 leaking?
cyl#1-180
cyl#2-155
cyl#3-175
cyl#4-180
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC »</TD></TR><TR><TD CLASS="quote">What % was #2 leaking?</TD></TR></TABLE>
we did it the old school way.... air line directly into the spark plug hole. Heard some air coming out the oil cap, thats it.
