Cold start problem
Old Dec 23, 2007 | 05:51 PM
PA MATT's Avatar
Default Cold start problem
Since it's been a little colder here in Pennsylvania, I've been having a little difficulty starting my car. It normally starts right up, idles for a split second, and then turns off. I start the car again immediately and it bumps around a little at idle(3 bar and 880's, so I guess that should be expected.) It does this everytime it's started when cold. The other morning, I actually had to give it some gas once I had it started to keep it running. I'm running neptune with this setup, should I try upping the idle a little bit or look elsewhere? I'm open to any input on this.
Old Dec 24, 2007 | 03:25 AM
xenocron's Avatar
Default Re: Cold start problem (PA MATT)
What are you tuned on?
You need to adjust your Cranking Tables, Post Start and ECT Enrichment tables.
Old Dec 24, 2007 | 11:25 AM
PA MATT's Avatar
Default Re: Cold start problem (xenocron)
I was tuned this summer and then street tuned this fall on Neptune's tuner edition. I'll keep those things in mind, thanks for the help. At least I know it's something non-mechanical and can be fixed pretty easily...
Old Dec 24, 2007 | 01:51 PM
HiProfile's Avatar
Carb'd cars need a choke to start really cold, which basicly enriches the mixture. If your tuner didn't set the tables well (you can't simulate 10deg IAT's on a dyno), then it will can be too lean (or even too rich) upon very cold startup.
Tell your tuner, and maybe he'll do the changes for free.
Old Dec 24, 2007 | 04:11 PM
PA MATT's Avatar
Default Re: Cold start problem (HiProfile)
thanks for the advice again... Last I talked to him he said he would do something, however, it's hard for him to see the car when it's cold. When he street tunes it, I drive over 30 miles to see him and the car is warm by then. I'll see what I can do though. Thanks again for all your help
end005
Sep 28, 2012 03:47 AM
Spawne32
Jul 9, 2011 05:08 AM
95goldSE
Sep 12, 2007 03:38 PM
the.hamburglar
May 2, 2006 09:27 AM
GsTeg90
May 6, 2003 05:02 AM
