how much material can be taken off when honing cylinders?
Old 12-24-2007, 01:27 PM
.adam.'s Avatar
Default how much material can be taken off when honing cylinders?
after receiving my wiseco's, i realized that my piston to wall clearance is tighter than i would like. my bore needs to be .002 bigger and i was wondering if a machine shop could just hone it out that much because it's such a small amount .....
Old 12-24-2007, 01:33 PM
tealegg's Avatar
Default Re: how much material can be taken off when honing cylinders? (.adam.)
call the machine shop and ask what they would do. i think a nice hone should be ok, but thats just my .02
Old 12-24-2007, 01:47 PM
.adam.'s Avatar
as bad as it sounds i trust the knowledgeable members of ht alot more than any of the machine shops in my area....
Old 12-24-2007, 02:09 PM
tealegg's Avatar
Default Re: (.adam.)
yeah i know what your saying there.. kinda the same around here as well. good luck on your build.
Old 12-24-2007, 02:47 PM
Man U FTW
Schister66's Avatar
What sleeves do you have and what bore are they at?
Stock can safely go to 81.5mm and aftermarket are good to 85mm for boosted applications
Old 12-24-2007, 03:42 PM
BadWay's Avatar
yes, any reputable automotive machine shop should be fully capable of this, as when they bore a block it is just a rough cut and the hone is used for final sizing.
Old 12-24-2007, 03:53 PM
JaredKaragen's Avatar
Default Re: how much material can be taken off when honing cylinders? (BadWay)
if your going F/I you want to take as little as possible out.
If your goin N/A, you can take more than you would think is safe.
It all depends on the motor and setup; along with the fact that if your not running excessive cylinder pressures you don't need to worry about cracking a sleeve.
Old 12-24-2007, 03:54 PM
dude, taking another .002 off won't hurt anthing unless you are like 50 or 60 over..
Old 12-24-2007, 04:17 PM
.adam.'s Avatar
they are darton sleeves nothing to worry about....
Old 12-24-2007, 04:34 PM
HiProfile's Avatar
My wisecos came slightly off from each other. Ideally you give your pistons to the machine shop to have the bores matched to the pistons. With a computer controlled honing machine, they can take as little or as much off as they need to. Its common for shops to only hone, as it can easily take off the 0.5mm called for to rebore a normal cylinder.
g0tgot
06-15-2008 03:56 PM
boostincoupe
10-27-2007 08:41 AM
EnzoSpeed
07-11-2005 08:32 PM
94tegdude
02-15-2005 10:33 PM
JUNEK9
02-01-2005 05:25 PM
Quick Reply: how much material can be taken off when honing cylinders?
