Code 43 check engine light
Old Jul 4, 2006 | 01:20 PM
94siludeturbo's Avatar
Default Code 43 check engine light
when i im boosting for about 10 seconds on my prelude it throws a code 43 with is the heated O2 sensor but why is it throwing this code im not running lean(pulled the plugs and they are burning a chocolate color. normal driving (when im not WOT) the engine light does not come on. any suggestions
Old Jul 4, 2006 | 01:30 PM
Bseriescivic5's Avatar
I have a very similar problem except mine comes on randomly both WOT and not. My setup: EG hatch b16a turbo. 13psi
Old Jul 4, 2006 | 03:16 PM
Default Re: Code 43 check engine light (94siludeturbo)
any suggestions
Old Jul 4, 2006 | 03:25 PM
DaveF's Avatar
get a new 02 sensor.
Old Jul 4, 2006 | 04:32 PM
I have a brand new bosch
Old Jul 4, 2006 | 04:50 PM
b18ccivics's Avatar
Default Re: (Bseriescivic5)
make sure you have 12v on one of the black wires, (with the key on) the other black wire goes straight to the ecu check and see if you are getting a good connection. make sure the resistance between the black wires on the sensor is around 15ohms i think (sensor disconnected). what year and model prelude do you have? i will look up what pin at the ecu the black wire is hooked up to.
Old Jul 4, 2006 | 08:10 PM
well i just bought a new o2 sensor about 2 months ago its a 94 prelude with the H23a1 in it
Old Jul 5, 2006 | 12:37 PM
any ideas
Old Jul 5, 2006 | 03:17 PM
b18ccivics's Avatar
a6 is the pin at the ecu for the o2 heater circuit.
Old Jul 5, 2006 | 03:31 PM
Default Re: (b18ccivics)
i think i have it fix i looked at my missing link check valve on the map sensor and it wasnt tight i could blow through it (not good) i tighted it down and now it doesnt seem to be causing me any problems thanks for you input
Old Jul 6, 2006 | 10:50 AM
4potnick's Avatar
Default Re: Code 43 check engine light (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseriescivic5 &raquo;</TD></TR><TR><TD CLASS="quote">I have a brand new bosch</TD></TR></TABLE> That's what you get using a bosch. been through many new boschs that didn't last 6 months or even work from the beginning. You can get oem pieces for about $60 on ebay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">get a new 02 sensor. </TD></TR></TABLE> just don't get a bosch
jayrod7
Jan 21, 2010 01:45 PM
mtime
Dec 17, 2009 09:17 PM
mseawell
Jan 17, 2005 09:14 PM
yellowcrx13
Jan 21, 2004 03:41 PM
yOnKiNaToR
Jan 11, 2004 09:46 AM
