ecu code #41
Old Nov 28, 2006 | 07:25 PM
jikespingleton's Avatar
Default ecu code #41
can anybody tell me wat code #41 is? also can anybody send me a link on honda codes so i dont have to ask a similar question in the future.
Old Nov 28, 2006 | 07:33 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: ecu code #41 (jikespingleton)
here you go http://www.c-speedracing.com/faq/05.php
OR just use the trusty honda-tech FAQ https://honda-tech.com/zerothread?id=978933
Old Nov 28, 2006 | 07:42 PM
Fat Chick Magnet's Avatar
41 Primary oxygen sensor heater
maybe need a new o2 sensor?
someone help this guy out!
Old Nov 28, 2006 | 08:31 PM
Kafelatte's Avatar
check your wiring. if not that then replace the o2. i've been driving with that code on for almost 2 years now. doesn't seem to hurt the performance. some people with test pipe runs without there o2.
Old Nov 28, 2006 | 10:13 PM
heres another question. wats a vtec pressure valve?
Old Nov 29, 2006 | 12:35 PM
anyone?
Old Nov 29, 2006 | 04:36 PM
come on im sure some one on here knows wat one is.
Old Nov 29, 2006 | 05:39 PM
JasonST's Avatar
I've gotten code 41 a couple times and every time it's because the connector to the sensor came unplugged, so I would check that, then check the wiring. As far as the Vtec pressure valve I think u mean the Vtec pressure switch. It's used to detect oil pressure inside the engine and make sure it has enough oil and pressure to engage and sustain Vtec. The Vtec pressure switch is only found on obd1 engines and ecu's too, from what I've read and seen.
JDMhondalude22
Nov 8, 2006 04:55 AM
5po0n_Dc2
Feb 24, 2005 04:13 AM
freakin_eLRoD
10
May 2, 2004 09:12 AM
BlackB18CTeg
Mar 7, 2003 01:12 PM
mannysir
Apr 20, 2002 02:19 PM
