Clutch slipping causing turbo to smoke?
Old 09-21-2004, 06:21 PM
ej8
ej8's Avatar
Default Clutch slipping causing turbo to smoke?
I can drive my car normal and it doesnt smoke, even in low boost, but when i get on it and the clutch starts slipping (new one going in tomorrow) it smokes, then i can drive it normal or let it idle for a few minutes, and then drive it and it doesnt smoke until the clutch starts slipping again.
The smoke is oil burning, the BOV is blowing oil, and the turbo is brand new. The oil return line is not pinched, and I am running an oil restrictor.
Is it possible that when the load gets taken off the motor real quick and the motor revs (clutch slipping), it causes it to burn oil somehow?
Any help is appreciated, thanks!
Old 09-21-2004, 06:24 PM
94dxt's Avatar
Default Re: Clutch slipping causing turbo to smoke? (ej8)
really doubt it, sounds like turbo seals
Old 09-21-2004, 06:45 PM
ej8
ej8's Avatar
Default Re: Clutch slipping causing turbo to smoke? (94dxt)
brand new seals, doesnt smoke at idle and pre to low boost
Old 09-21-2004, 06:46 PM
ej8
ej8's Avatar
I'm puttng the clutch in tomorrow and ive got an extra turbine seal just incase, but would that cause it to dump oil in the intake?
brians356
09-23-2013 01:47 PM
norcalB18
11-08-2010 03:19 PM
924doorEG
05-01-2008 02:36 PM
autoxthis
12-07-2007 04:18 PM
del soler
10-03-2004 06:12 AM
Quick Reply: Clutch slipping causing turbo to smoke?
