Clutch 101 by Rocket
I have a fidanza 9 lb flywheel, clutchnet 6 puc and their dual diaphram pp. When would you recommend dropping the tranny and having a look at the flywheel? I'd really hate to chew up the fidanza seeing that it wasn't exactly cheap.
Rocket,
What is your opinion on the new Tilton clutches and PPs. I noticed you have not listed them. I know they are expensive and the new product is relatively new, so you may not have seen one. But I have read articles that herald this new clutch as a great addition to powerful Hondas.
X2
X2
I have a DailyDriven GS-R. And there's a good chance that I'll be in a lot of traffic. What's a good setup that has good pedal feel (but not too hard) and longevity?
HOW TO RECOMMEND A CLUTCH
This is a question I am asked very often, "Which clutch should I get?" I usually have 2 to 3 clutches in mind but since the clutch affects the way you interact with your car a clutch seller should try as best as possible to understand BOTH buyer and the buyers car. The general rule is the more hard core you are the more likely I recommend a puck disc. The more conservative you are I would recommend kelvar.
...more to come
Who make's a good segmented Kevlar disc?
Does a disc alone increase the torque capacity of the entire clutch?
How is a segmented kevlar disc differ from a straight kevlar? torque capacity?
Action has good segmented Kevlar discs like the one pictured in the earlier posts.
The reason for segmentd vs. full face Kevlar is that Kevlar needs more pressure to work properly.
Yes, torque holding capability can dramatically increase with different friction materials. It's measured by what engineers called coefficient of friction. The lower the coefficient of friction to more force is needed produce the same holding power.
Copper Ceramic has one of the highest (but tends to break up under heat). Kevlar actually also has high coefficient of friction almost approaching that if the sintered metallic pucks.
Rocket,
X2
X2
My personal opinion on RPS is that Rob Smith does a good job of marketing. I've never got my hands on any of his clutches because not many people run them here in LA. Kinda makes you think doesn't it.
[Modified by Rocket, 9:31 PM 6/27/2002]
ACT makes really good pressure plates and clutchnet makes really good discs.... would it be a good combination to run an ACT pressure plate with a clutchnet disc for a 500hp daily driven honda?? I would like to keep the pedal feel as close to stock as possible with the engagement somewhat smooth.... What would u recommend i run? I cant find information on the Action Clutches.... I am getting mixed results on ACT and Clutchmasters...
The only bad thing that I've heard about ClutchMasters is the springs tend to pop out to easily. What if I never launch at high rpm (4k or lower), would you consider a CM stage 3 is a good clutch for daily driving? TIA.
However, this thread is not meant as plug for Action, it is meant as a Educational post, and I have tried my best to explain what I know about clutches without bias.
any review on clutch specialties? how come i've heard some brands are just the same clutch as others? is that weird? good post
i needed this lesson. especially the part on material and construction of the disc.
[Modified by Eggman, 11:41 AM 6/28/2002]
i needed this lesson. especially the part on material and construction of the disc.[Modified by Eggman, 11:41 AM 6/28/2002]
What do you think of Exedy clutches? Because when I first got it in the mail, it look liked a basically stock unit? is it? From what it says on their website, its supposively able to handle up to like 300lbs of torque, and this is their organic unit..
Did you get the standard, or the "racing" organic ? I was under the impression that the standard one was OEM, and the racing was a bit more aggressive. I'm thinking of getting the racing organic soon, so I'd appreciate some more info
Not the 3-puck ones, the solid disk organic ones. Supposedly 32% "capacity increase."
http://clutchcityonline.com/Merchant...t_Code=08-800B
I'm looking for something pretty mild, but a little more aggressive than stock, and possibly complimented with a light flywheel (as I'm not FI, and not even bolt-on'ed yet
Their clamping load figures are way low.
Pedal pressue stock is higher than this so clamping force is about 5 times this due to leverage. Clamping force is a multiple of pedal pressue due to leverage. Look at my diagram and you can see why.
How good are the Exedy pessure plate's though?
Mine said it was at 70% over stock.(212MM 90-90 civic/crx)
I was thinking of using my Exedy "racing" pressure plate with an Action Kevlar disc.
What do you think the limit's of that are?
I'm trying for 350HP, but I am not going to be doing much track driving. Will this setup work?
[Modified by Bryson, 1:14 PM 6/28/2002]
