civic with b18b1 turbo
Old Mar 25, 2014 | 02:57 PM
manuel351's Avatar
Default civic with b18b1 turbo
hi guys recently i bough a 97 civic with a b18b1 turbo with a s80 tranny upgrades that i know off rc injectors dont know size hks blow off tial 38mm westgate skunk 2 suspension and an ebay turbo kit car is setup for turbo and the wiring was made as well dont know what ecu is using but i was told it was tuned i did a compression test was 170/170/165/170 recently it started smoking when on neutral verify the turbo and it play back and forward like 2 mm the size of the turbo is a t3/t4 cold side AR60 im looking for a replacement but it has to be a affordable one cause im running low on money and my boy's birthday is coming what you guys recommend also i bough an AEM wideband to install and have heard so many stories on where to install the sensor that i dont know any help would be most appreciated
Old Mar 25, 2014 | 03:10 PM
TravisBiggie's Avatar
Default Re: civic with b18b1 turbo
Complete sentences will make it easier for us to help you and understand, that was painful reading. Is there burnt oil below the turbine housing? That would indicate a bad oil seal. Also, do you know what kind of restrictor it has? What size turbo oil feed? Is the oil drain vertical? If you plan to replace the turbo, budget $500, unless you buy another ebay turbo. Have an exhaust shop weld in the 02 bung 12"-24" from the turbo outlet.
Protip : use the search button
Old Mar 25, 2014 | 06:15 PM
TheShodan's Avatar
Moderator
Make sure your boy understands that his gift may not be as big as he'd hope for his birthday, because you'll need more than $500 for a newer quality turbo (it must be the same size, or you'll need to get re-tuned).
You'll need to know what it is you HAVE. start looking at your equipment. without this information, your boy's birthday gift won't be the only thing you won't be able to afford.
ACrite3404
Mar 4, 2008 08:33 AM
slowcrxsib16
Sep 26, 2007 06:00 AM
dan's integra
Dec 29, 2005 12:52 PM
Black R
May 27, 2004 04:57 AM
VtecInteg95
Oct 29, 2002 07:19 PM
