chunks of ringlands
Old May 21, 2006 | 08:39 PM
spoolinegsr's Avatar
Default chunks of ringlands
well, i had a thread earlier about what happened
https://honda-tech.com/zerothread?id=1634898
well, we ripped it apart, and i busted the ringlands on 8psi........
cylinder 1
cylinder 2
cylinder 3
and cylinder 4 had a hairline crack..
the rings were fine too
we did find a block guard on the bottom end tho
what a good excuse to build a bottom end
where is a good spot where i can learn how to tune?
Old May 21, 2006 | 09:02 PM
ccivic's Avatar
Default Re: chunks of ringlands (spoolinegsr)
http://www.pgmfi.org
Old May 21, 2006 | 11:03 PM
HamiltonRex's Avatar
Default Re: chunks of ringlands (ccivic)
Wow that sucks, what was your tune like?
Old May 22, 2006 | 12:09 AM
Default Re: chunks of ringlands (HamiltonRex)
what do you mean what was my tune like? i get so many differnt opinions on how to tune etc etc, i want to learn how to do it myself so i can have a say in it next time around. i just dont get what taking timing out does, and how that affects egt's, and how many degrees do what blah blah blah, i also dont understand where to start with fuel maps. do you just start it at target afr's and then work your way up in the rpm range?
Old May 22, 2006 | 05:49 AM
mrbsponge's Avatar
chances are you may have had a stock motor that was probably beat up on a bit, especialy if you "found" a blockguard, someone put it there for a reason.
ringlands usually go from too much timing, too lean of a condition, both.
think of timing like this: if you pull too much timing the combustion takes place later, and this is evident in DSMs, so much that thier manifolds start to glow because most of the combustion is taking place towards the exit, or almost in the manifold
add to much and it starts to happen the other way, ie: towards thei ntake side, but with both of these very different conditions, it plays a huge part on our motors moving parts
Old May 22, 2006 | 09:58 AM
yee SERIOUS's Avatar
how about efi101.com
koumatae
Jun 19, 2012 11:55 AM
mrgar
Aug 12, 2009 07:30 AM
hmtcrxsir
Jun 19, 2009 09:21 PM
SiR Adam
Feb 24, 2006 09:27 AM
turboedc2
May 30, 2005 08:28 AM
