Code 22... any help/advice welcomed...
Old May 22, 2006 | 09:20 AM
turboH22Aakkord's Avatar
Default Code 22... any help/advice welcomed...
ok.. ive got a boosted h22... and it has sat all winter in storage and now its up and running again... im running uberdata and the car runs fine.. however im getting a constant cel light and its code 22 which is vtec pressure valve, and obvosly vtec isnt engaging at this point... has anyone ever gotten this code and how do i fix it? would replacing the whole solenoid fix it? thanks guys... and if you think i should post in a different section... please say so...
Old May 22, 2006 | 09:40 AM
Default Re: Code 22... any help/advice welcomed... (turboH22Aakkord)
ttt anyone?
Old May 22, 2006 | 09:49 AM
Meat_Wagon's Avatar
can't you just go into uberdata and tell it not to check for vtec pressure?
Old May 22, 2006 | 10:12 AM
ekhatchgrl's Avatar
I might check continuity (spelling) from the pressure switch to the ecu and make sure nothing happened to the signal path.
Old May 22, 2006 | 10:31 AM
Default Re: (ekhatchgrl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatchgrl &raquo;</TD></TR><TR><TD CLASS="quote">I might check continuity (spelling) from the pressure switch to the ecu and make sure nothing happened to the signal path.</TD></TR></TABLE>
yeah.. i just googled this and found some good info .. im going to check the continuity.. and i guess there is a filter that might need cleaning in the vtec unit itself.. any one else with any info? ( thanks guys)
saintbhts
Jun 12, 2013 09:43 PM
racereaper7
Aug 14, 2007 08:56 AM
aleminx
Feb 18, 2006 07:25 AM
scythemk
Jan 29, 2006 10:10 AM
ViXoN Hatch94
Nov 28, 2005 01:40 AM
