chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu?
Old 10-14-2003, 02:47 PM
baphomet's Avatar
Default chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu?
Old 10-14-2003, 02:49 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Default Re: chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu? (
swaping out an ecu should kill the memory, but if not just undo the battery.
Old 10-14-2003, 03:03 PM
omahaturbocivic's Avatar
Unplugging the ecu is all that needs to be done to clear it. I have changed chips at the track with only shutting the car off and the launch rpm would change but I believe blake had observed that the fuel may not instantly be changed even in open loop unless the ecu is cleared.
Old 10-14-2003, 04:24 PM
baphomet's Avatar
I was concerned about maybe blowing a fuse or something if thebatery was connected.
Old 10-14-2003, 05:42 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
Naw i never had a problem
Old 10-14-2003, 06:27 PM
Mr. Softee's Avatar
no, thank god.
jamclaur
07-21-2005 09:04 AM
T--Rex
07-27-2004 10:53 PM
bigslimdog
03-30-2004 03:07 PM
dvcart106
08-09-2003 12:42 PM
rock2447
01-15-2003 02:42 PM
Quick Reply: chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu?
