chipped crank pulley:( still good?
I broke a piece off my crank pulley. I was wondering if the missing piece would throw the balance off. What do you think? Will it be ok to use?
Re: chipped crank pulley:( still good? (small arm)
Ive broke a small piece off of mine before, but thats ginormous. Out of balance obviously, how much, I dont know. But do you want to find out at 8500rpm?
Pretty easy fix if that bolt isnt seized
Re: (ARAXIS)
I don't know what it looks like to you in the pic but only the lip is missing nothing else.
I was holding the pulley with a chain wrench to brake the bolt loose. I did it many times on my other engine and had no problem. This is a 95 engine so the metal may be more fatigued.
I think I have another crank pulley at my disposal so I'll change it over
ive put in motors with chipped crank pulley's before and ran them fine, even raced them hard alot, i havent experienced' any problems with crank pulley or crank failure
Re: (small arm)
they are really easy to break edges off like that. my h22 pulley has chips all over it but i don't use it anymore due to me getting a fluidampr.
Re: chipped crank pulley:( still good? (PrecisionH23a)
Yea, the longblock I bought had a pully that looked the same way. I ended up getting a fluidamper. Just make sure you have a harmonic balancer puller ($20 oriley's) because it's a bitch to get on/off.
Re: chipped crank pulley:( still good? (sp00led)
****, if you think thats bad you should see mine. ive been driving and beating on my car for 4 years now ;P
never thought of the balance til now. i guess i should replace mine too
SuicideSlide
10-09-2004 08:27 AM
