Chip Worries
Old Jul 13, 2003 | 11:56 AM
ScottEK's Avatar
Default Chip Worries
I'm turboing my car this week and at the same time I'm chipping my PR3 ECU. I'm getting the Mugen N1 chip and the Spoon program but I'm worried that they might effect the timing maps the wrong way for boost. I would stick with the stock program but I was sent an automatic ECU with my swap from password jdm. Thanks for any advice,
If it helps I'm running a B15 w/ a T3 .60 .63 running the AFC Hack and can't afford a BTM right now.
Old Jul 13, 2003 | 12:01 PM
tegasaurus's Avatar
Default Re: Chip Worries (beta13)
find a new virgin manual ecu, do NOT get any N/A program for a boosted motor, it'll go straight to hell
-ryan
Old Jul 13, 2003 | 12:50 PM
swrdply400mrelay's Avatar
Get a boost chip such as the Uberchip.
Old Jul 13, 2003 | 12:51 PM
ScottEK's Avatar
Default Re: Chip Worries (swrdply400mrelay)
AFC hack and uberchip?
Also isn't uberchip only for obd-1?
Old Jul 13, 2003 | 01:03 PM
int3gra's Avatar
Yes Uber is OBD1
Old Jul 13, 2003 | 06:58 PM
Spunkster's Avatar
Get a Hondata, then you can get it fully tuned for boost and have it prperly tuned so it feels like it came from HOnda with the turbo.
Old Jul 13, 2003 | 09:33 PM
Joseph Davis's Avatar
Default Re: Chip Worries (Spunkster)
Direct your favorite ECU chipper to http://www.pgmfi.org/phorum/read.php?f=35&i=1&t=1
The required .bins are at the absolute bottom of the thread, configured for stock (euro, actually) NA timing and 1.0 deg/psi retard under boost, for use with AFC hack or MAPhack setups. You still need to tune your fuel maps as per the usual AFC hack.
You're welcome, I did the PR3 ignition maps back in the bad old days of hand calculation with spreadsheets and hex editors. **** the sissy "I need a tuner app" bullshit I hear these days.
Old Jul 14, 2003 | 12:05 AM
nevin's Avatar
Im looking for boost pr4 .bins. Can anyone help?
Old Jul 14, 2003 | 06:10 AM
Default Re: (nevin)
Which?
Old Jul 14, 2003 | 09:24 AM
ScottEK's Avatar
Default Re: (J. Davis)
JDavis, you have found EXACTLY what I have been looking for thank you so much.
EDIT: After reading that entire thread I have some questions:
1. Is this bin intended for use on the PM6 or PR3 board?
2. What were the changes to the pr3 bin, it said the high cam was unchanged?
3. Where is fuel cutoff on that PR3 bin?
4. So when I'm ready to go do I just tune the VAFC hack like normal by starting at -35 across the board? Where do I set my distributor timing to if this is taking care of ignition retarding?
Modified by beta13 at 12:53 PM 7/14/2003
Old Jul 14, 2003 | 07:12 PM
Default Re: (beta13)
1) The LS and Si MAPhack are meant for use on OBD0 PM6 and PR4. The PR3 and PW0 MAPhacks are for use with their respective B16A1 ECUs.
2) The first PR3 MAPhack was a partial save of some work I had done, not the completed .bin which was lost in a HD crash. It only has the low cam ignition set up for AFC/MAP hack. The second one, posted with the PW0 MAPhack, is the correct one with both high and low cam ignition tables corrected.
3) Stock 8K redline, would you like I change that and/or VTEC for you?
4) Start -40%-ish in the lower pre-spool revs and add fuel up to wherever you have to under boost, according to your AF gauge/O2 voltage/preferrably wideband O2. Set your dizzy timing to stock, 16 degrees.
Old Jul 16, 2003 | 02:08 AM
nevin's Avatar
i was looking for pr4 maphack .bin for b18a motor but i cant find any tunes for obd0 b18a's. I have some stock bins and na programs but im looking for one with boost tables and the retard per psi. thanks
Old Jul 16, 2003 | 02:12 AM
nevin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">4) Start -40%-ish in the lower pre-spool revs and add fuel up to wherever you have to under boost, according to your AF gauge/O2 voltage/preferrably wideband O2. Set your dizzy timing to stock, 16 degrees.
I thought the map was scaled for 450ccs so you didnt have to use an afc?
blasterman87
Sep 26, 2009 04:29 PM
white2draccord
Apr 27, 2008 09:21 PM
T-RO
Aug 26, 2003 11:40 AM
PressurizedSi
Dec 30, 2002 06:15 AM
blundar
Sep 7, 2002 06:41 PM
