Check this out...
Old Mar 15, 2004 | 04:15 PM
95lsteg's Avatar
Default Check this out...
Suddenly my car is making "pinging" noises. Its a 95 ls teg (everything stock), It has not being drive hard or anything like that. It sounds like when you use cheap gasoline. First I thought that was the problem, but after switching from 3 diff brands (high octane of course) I have discarded that option.
I'm asking here bec I have a turbo kit ready to be fix in the car, and this is stoping me from starting.
What could be the problem?
Old Mar 15, 2004 | 04:22 PM
Bulldogg83's Avatar
Default Re: Check this out... (95lsteg)
sounds like detination.......how many pounds you running?
Old Mar 15, 2004 | 04:30 PM
95lsteg's Avatar
Default Re: Check this out... (Bulldogg83)
No, no... The car is completely stock, that's why I'm worried. The turbo kit is still not in the car. I have to fix this problem to then start working on making it turbo.
Old Mar 15, 2004 | 04:31 PM
Bulldogg83's Avatar
gotcha.....pinging usually means detination....you low on oil any of notice any oil leaks anywhere?
Old Mar 15, 2004 | 04:40 PM
95lsteg's Avatar
No oil leaks or smoke at the muffler. Also it runs great.
It is consuming a little bit of oil dough.
Old Mar 15, 2004 | 04:41 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
or you could be getting blow by from the breather system and it's throwing oil back in the cylinders
Old Mar 15, 2004 | 04:43 PM
95lsteg's Avatar
Default Re: Check this out... (HybridcivicLS-T)
How do I verify that?
Old Mar 15, 2004 | 05:01 PM
95lsteg's Avatar
What should I do... Compression test? How do I test the breather?
Old Mar 15, 2004 | 05:09 PM
jmagner's Avatar
Not sure how to test the breather but you should take a look at your plugs that might tell you something about whats happening in your engine.
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lsteg &raquo;</TD></TR><TR><TD CLASS="quote">How do I verify that?</TD></TR></TABLE>
take the breather that connects from the head to the intake and see if it's oil in it.
Old Mar 15, 2004 | 05:10 PM
jdm91integ's Avatar
Check your timing maybe? Your timing could be advanced too far causing the motor to ping even with premium gas. Just a thought.
Old Mar 15, 2004 | 05:12 PM
Drew Peacock's Avatar
MMM chances are there will be some, a little blow by is normal yeah compression test should tell you,.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">
take the breather that connects from the head to the intake and see if it's oil in it.</TD></TR></TABLE>
Old Mar 15, 2004 | 05:14 PM
95lsteg's Avatar
Thanks!
I'm going to check the breather tomorrow first thing in the morning. What should I look for in the plugs? Timing is supossed to be the same from factory but will check it anyways.
Old Mar 15, 2004 | 05:23 PM
jmagner's Avatar
http://www.theultralightplace.com/sparkplugs.htm
That shows many spark plug conditions, try and match it up. That page says its for Rotax engines but those pictures are accurate for Hondas as well.
LazJDM
10
Feb 2, 2009 07:53 AM
FRESHTEG
Jun 8, 2008 06:25 PM
PINKS
Aug 3, 2006 12:32 PM
Luchini
Feb 1, 2006 12:51 AM
goofball123321
Oct 9, 2003 09:52 PM
