Check this....never seen it before
Old May 29, 2007 | 05:07 PM
m R g S r's Avatar
Default Check this....never seen it before
wastegate v band adapted to fit onto the turbine housing....how do you think flow is on this?
And i don't know how that divider isn't going to hit the WG piston....spacer maybe? but then it would kinda ruin the whole divided housing thing. . .
Old May 29, 2007 | 05:34 PM
Pay2play killa's Avatar
Default Re: Check this....never seen it before (m R g S r)
thats the best place to put a wastegate; the wastgate has to "work" less to get the gases out of the system.
the divider is there to keep the turbine housing divided though i have no idea what benefit if any that provides.
Old May 29, 2007 | 05:38 PM
m R g S r's Avatar
Default Re: Check this....never seen it before (Pay2play killa)
I kno why its there....but won't that hit the piston of the WG? And if it doesn't, say some sort of spacer is used....that will defeat the purpose of the divided housing, because exhaust gasses can flow between the two sides, no?
Old May 29, 2007 | 05:42 PM
k24em2's Avatar
The wastegate valve doesn't sit flush with the bottom of the flange.
Old May 29, 2007 | 05:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">I kno why its there....but won't that hit the piston of the WG? And if it doesn't, say some sort of spacer is used....that will defeat the purpose of the divided housing, because exhaust gasses can flow between the two sides, no?
like k24 said; the v-band gates sit pretty high up; they probably made that spacer to sit as close to the valve as possible; it may or may not have been shortened some more when they test fit it.......
without knowing more its hard to say
/edit': and unless i'm missing something that picture is flipped horrizontally
Old May 29, 2007 | 06:01 PM
EJ1 wilcox's Avatar
I see what you are saying about the wastegate valve. The valve has to seal when the wastegate is closed, or it will leak exhaust and kill spool.
I'd like to see how they are sealing that divided flange against the wastegate valve.
OT: That turbo is tilted too far. Very poor manifold design. That's going to kill the bearings.
Old May 29, 2007 | 06:19 PM
miller's Avatar
Default Re: Check this....never seen it before (EJ1 wilcox)
IF it were me and i was gonna go through the extent of modifing the turbine housing like that i would have went down more on the housing itself to give the wastegate a more direct hit. Just my $.02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">OT: That turbo is tilted too far. Very poor manifold design. That's going to kill the bearings. </TD></TR></TABLE>
my thoughts exactly, oiling was deff not thought of when this design or lack there of took place. The angle seems a bit to much.
kb58
Jun 13, 2008 10:13 PM
aalb1
Mar 29, 2006 10:16 PM
b00st Junkie
Nov 25, 2005 02:59 PM
RACEPAK
Mar 3, 2005 12:11 PM
civictypenos
Aug 1, 2003 09:38 PM
