why are turbo track times less then NA????
why are turbo track times not as fast as NA
hey guys, this may be a newbie question, but humor me please, im not too familiar with turbo set ups.....ive looked at a few instances and noticed that NA guys with roughly 180-200hp are running mid to low 13's give or take......and turbo guys with over 200hp are running the same numbers maybe a little lower but not by very much.....now why is this???? I realize i have to take into account driver skill, however i was wondering if all things constant, meaning driver ability, car weight, tire psi etc, what set up would have the potential to be a faster car....fast spooling small turbo also, same hp. would it be a drivers race???? The reason i ask is because it seems the k series is the new wave, i have an EK hatch and i can't afford to swap the K. So to be competitive im leaning towards a turbo kit (stock b18c1 motor thinking of building that for boost) Need some constructive thoughts. Thanks in advance.
edit: sorry for messing up the title wasn't thinking when i first posted.
Re: why are turbo track times not as fast as NA (Godspeed07)
wow this is going to be a fun post if everyone gets on it
there has been numerous post that end up a big argument over this topic.
now to start it off
i would think that the FI would have the advantage if all variables were equal due to the fact that the FI will have more trq.
however that is what i understand through my research not from first hand so...
now to start it off
i think its power band related
most turbo cars (depending on turbo size) only have a certian amount of usable rpm range. such as max boost to redline
where as the n/a motors make power even down low were in a turbo car the turbo is not spooling yet
correct me if im wrong
Re: (BlackCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackCRX »</TD></TR><TR><TD CLASS="quote">i think its power band related
correct me if im wrong</TD></TR></TABLE>
but in a drag race how long are you in that rpm range?
the trq would more than make up for that short amount of time i would think
I believed you answer your own question...lol. Weight of car, tires and driver makes a huge difference.
As for your situation, If you already have the B18c1 in your car, then boosting it would be a feasible option. You should make at least 250-270 whp depending on your setup and with some slicks, that should be good enough for some low 13's maybe high 12's if you can drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Godspeed07 »</TD></TR><TR><TD CLASS="quote">I realize i have to take into account driver skill, however i was wondering if all things constant, meaning driver ability, car weight, tire psi etc, what set up would have the potential to be a faster car....fast spooling small turbo also, same hp. would it be a drivers race???? </TD></TR></TABLE>
Re: (95jeremie)
first off im sorry if this has been covered already,.....id love to find maybe a 235hp turbo dyno and a 235 na dyno to compare where the power comes on, on the same motor........i understand that na power comes on right from the get go, but im curious to know that maybe because of excessive power in turbo apps, the power is not getting to the ground like on na applications.......so would a detune or lowering of the boost be benificial???
Re: (Max500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max500 »</TD></TR><TR><TD CLASS="quote">I believed you answer your own question...lol. Weight of car, tires and driver makes a huge difference.
As for your situation, If you already have the B18c1 in your car, then boosting it would be a feasible option. You should make at least 250-270 whp depending on your setup and with some slicks, that should be good enough for some low 13's maybe high 12's if you can drive.</TD></TR></TABLE>
right....but i was wondering, in my chassis, wouldn't 250-270 get me deep into the low 12's na????
Re: (Godspeed07)
gear based boost controllers
lets you run the most power possible per gear to keep traction
and don't worry about it
i would rather see this over "I want to install my intercooler but can't figure it out without cutting or drilling something" ( https://honda-tech.com/zerothread?id=1992407 ) all tho it was funny
Re: (95jeremie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jeremie »</TD></TR><TR><TD CLASS="quote">gear based boost controllers
so how would i tune/set a gear based boost controller??? running at the track and finding what works???? also what kind would you suggest i buy??
Re: (Godspeed07)
once again not from experience because I'm still building my kit but i have the APEXI AVC-R
https://honda-tech.com/zerothread?id=1037051
https://honda-tech.com/zerothread?id=1966856
even tho I'm not boosted yet i have it hooked up and it is easy to use and looks good to
Re: (95jeremie)
awesome thanks.... boost it is then.....this set up will actually be for track racing....well this is my hope for the car in the future at least, but some practice at the drag strip would be great too....i really want to be able to hang with a K series, i don't think that it will ever be an option for me. Thanks again....any other comments welcome.
Re: (95jeremie)
hmmmm interesting....thanks for all the replys guys, its confirming a few thoughts i had, i think my goals are going to be low boost to start off with to see how fast i can get the car at minimal hp settings....thanks again Honda Tech yaaaayyyyaah!
Re: (Godspeed07)
asked the same question a while ago, with a lot of dumb responses but there are a few good ones...
https://honda-tech.com/zero...age=3
Re: (93CX)
it is all about tracksion last year at the track with my lsvtec turbo coupe ran a 117 trap at a13.6 wow with drag tires went a 12.2 at 118
Re: (95jeremie)
lets you run the most power possible per gear to keep traction</TD></TR></TABLE>
n/a has instant power at all times turbo doesnt have instant power due to having to wait for the turbo to spool up and make teh power that matter of time it needs makes a diffrence. n/a also makes power low end but not most turbo setups
* B A N N E D *
Re: why are turbo track times not as fast as NA (gsrturbo-ek)
i have ls vtec boosting 7 psi @ 234 whp and i dont even hit 13's Best time was 14 flat. I must suck at launching with the federal street tires. 195 50 515. i have 2.36 60 ft
ok heres my opinion...i think the na cars dont spin as much so less spinning means more "go"...plus with the turbo its hard to keep traction obviously....it seems easier to have a good launch in a na car too wich is the most important thing in a drag race, plus most na cars are gutted to the max...it has nothing to do with the powerband because in a drag race your in you powerband the whole time (if you can drive)...i beat a modded 06 wrx and it had a more useable powerband and more torque, but who needs torque when you rev high...
