check engine light when boosting
Old Aug 17, 2004 | 06:37 PM
  #26
POWERINTEGRA's Avatar
Default Re: check engine light when boosting (XBoostedAccordX)
Keep it low and save 5psi if there is no FMU or Hondata. With fmu and hondata you can run9-10 save. Try a fish tank is kind of like a missing link sometimes it works better but definitely you ecu is reading boost!!
Old Aug 17, 2004 | 06:47 PM
  #27
XBoostedAccordX's Avatar
Default Re: check engine light when boosting (POWERINTEGRA)
Thank you so much POWERINTEGRA for all your help. i will order a fmu right now. what ratio should i go with? im going to call a few places tomorrow to have the motor checked out. thanks again
Old Aug 17, 2004 | 07:09 PM
  #28
A 12:1 FMU, for example, will increase fuel pressure by 12 psi per psi of boost. It is recommmended that a 10:1 or 12:1 ratio FMU be used in order to ensure that the A/F mix will not be lean. Try vortech!
Old Aug 17, 2004 | 10:47 PM
  #29
SOHC_MShue's Avatar
man screw the fmu. At least get an afc or something and run some 450cc injectors. The fmu is just gonna make you run really rich...its still better than what you have now though
GSE980
Jan 24, 2010 04:50 PM
Mr.Death
Jun 11, 2009 06:09 AM
DXK Eg
Aug 3, 2006 05:38 AM
DXK Eg
Jul 20, 2006 10:30 AM
