Check engine light help?
Old Jul 17, 2002 | 09:55 PM
B20-T's Avatar
Default Check engine light help?
I have two check engine codes..ones a 17,and a 22..speed sensor and vtec ...My speed tachometer is goin crazy when i step on it or when i drive it normally..sometime it dont even work..and i think my alternator is bad..could this be the problem because it not gettn enought voltage to the vtec selenoid,and the speed sensor..please help me..i got a event coming up..thanks
Old Jul 17, 2002 | 10:42 PM
boostaholic's Avatar
Default Re: Check engine light help? (B20TURB0)
Check your fuses under the dash. The VSS and alternator run off the same fuse so it's likely you've blown it if you're having both those symptoms. I believe it's a 15 or 7.5amp fuse.
Old Jul 17, 2002 | 10:51 PM
B20-T's Avatar
Default Re: Check engine light help? (boostaholic)
what about code 22?can it be the alternaotor bad ?
Old Jul 17, 2002 | 10:56 PM
I don't have my ECU code chart handy right now. What's the error for a code 22? Any chance it's the ELD circuit?
Old Jul 17, 2002 | 11:21 PM
B20-T's Avatar
its the vtec selnoid and switch
Old Jul 18, 2002 | 12:13 AM
inspyral's Avatar
Do you have a VTEC controller? The ECM will sometimes throw a 22 if you've adjusted the VTEC engagement away from the stock point significantly.
Old Jul 18, 2002 | 12:23 AM
B20-T's Avatar
Default Re: Check engine light help? (inspyral)
oh no i dont have a vtec controller
Old Jul 18, 2002 | 09:52 AM
B20-T's Avatar
bump
smurfylee
Sep 18, 2008 02:23 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
jaydm ferio
11
Dec 13, 2004 07:19 PM
brian2903
May 2, 2004 12:10 PM
inzaneN1
Dec 3, 2003 01:34 AM
