check engine light comes on after cat install.
Old Oct 6, 2005 | 08:38 PM
silverintegra83's Avatar
Default check engine light comes on after cat install.
ok i have a b16a3 with drag 3 turbo kit. runnning vafc tuned at 6 psi. everything was fine until i had to pass emissions. so i had to go get a cat put on, it was straight pipe b4. well after i got the cat put on my check engine light comes on. ne one have ne suggestions?
thank you
Old Oct 7, 2005 | 07:44 AM
Default Re: check engine light comes on after cat install. (silverintegra83)
up ne help?
Old Oct 7, 2005 | 06:51 PM
help?
Old Oct 7, 2005 | 07:21 PM
Pullig's Avatar
well they are gonna want to know what code you are throwing for them to help u
Old Oct 7, 2005 | 08:02 PM
Default Re: check engine light comes on after cat install. (Pullig)
how do i find that out?
Old Oct 7, 2005 | 09:51 PM
rhettster's Avatar
You need to hook a code reader up to your ECU. Are you running any kind of engine management, because you may be able to get the code that way.
Does your cat have an O2 sensor bung in it?
Old Oct 7, 2005 | 10:57 PM
Default Re: check engine light comes on after cat install. (rhettster)
yes the o2 sensor has a bung(if by bung u mean the o2 sensor is screwed in) in it. and i am running vafc.
Modified by silverintegra83 at 4:34 PM 10/8/2005
Old Oct 8, 2005 | 02:10 PM
rhettster's Avatar
Bummer. I don't think the vafc has any code-reading capabilities. My guess is that your new cat doesn't do as good of a job as your old one, and the O2 sensor is picking that up...but that's just a guess.
You need someone to grab the code for you so you can tell exactly why that CEL is on.
Old Oct 8, 2005 | 08:42 PM
the one b4 was a straight pipe
brad98_teg
Mar 28, 2005 06:17 AM
Another_Teg_Owner
Dec 15, 2003 11:11 PM
tegrunner
Sep 11, 2003 07:54 PM
AllMotorBLKITR731
Oct 17, 2001 12:39 PM
