TurboXS duel stage manual boost controller
Old Aug 18, 2003 | 08:00 PM
ATS*Mark's Avatar
OG triple OG
Default TurboXS duel stage manual boost controller
just wondering if anybody has any experience with this , it looks pretty good , i was thinking about getting it.
Old Aug 18, 2003 | 09:14 PM
hatchback19's Avatar
Default Re: TurboXS duel stage manual boost controller (TURSpoonEK)
It works well except it's slightly decieving. You still need two manual boost controlers, the dual stage just switches between the two. It's more like a solinoid.
Old Aug 18, 2003 | 11:04 PM
Pat's Avatar
Pat
Default Re: TurboXS duel stage manual boost controller (hatchback19)
well when you buy it, you do get the 2 combined boost controllers. You could rig up a similar contraption for cheaper if you know electronics and stuff
Old Aug 18, 2003 | 11:07 PM
psileepR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchback19 &raquo;</TD></TR><TR><TD CLASS="quote">It works well except it's slightly decieving. You still need two manual boost controlers, the dual stage just switches between the two. It's more like a solinoid.</TD></TR></TABLE>
huh?
basically its 2 boost controllers... one you adjust for low boost. one is for high boost. the 2nd stage can only be equal or greater than the first one.
i like mine.. holds boost pretty good.
Old Aug 18, 2003 | 11:35 PM
nigel's Avatar
does a boost controller cause the turbo to spool faster?
Old Aug 19, 2003 | 04:02 AM
Happyman's Avatar
Default Re: (nigel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nigel &raquo;</TD></TR><TR><TD CLASS="quote">does a boost controller cause the turbo to spool faster?</TD></TR></TABLE>
In most cases, yes.
Old Aug 19, 2003 | 05:20 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (Happyman)
for 165 on ebay i thought id give it a try.....
Old Aug 19, 2003 | 05:35 AM
Happyman's Avatar
Default Re: (TURSpoonEK)
Eh **** dual stang. Grab the Hallman with the cockpit adjuster. It's like 100 dollars. Can't go wrong.
15psi of fun
May 12, 2004 07:00 AM
Pfieff
Jul 13, 2003 04:58 PM
B20-T
Jun 25, 2002 06:12 AM
