Cel three when boosting how to fix?
Old Oct 19, 2003 | 06:10 PM
Kazz's Avatar
Default Cel three when boosting how to fix?
Okay my situation is I just finish with my head resurface and haed gasket replacement a couple weeks ago so then today i boosted. I boost at around 7 to 8lbs with a 96 gsr teg.. everytime i boost i get a cel three which is map sensor... but when i drive normal no code 3..
so my question is how to fix does that mean i have a bad map sensor?
Old Oct 19, 2003 | 07:58 PM
Johnyquest's Avatar
Default Re: Cel three when boosting how to fix? (JuuKe_EM)
no it means you drive a honda which doesn't have a boost map so you can't let your ecu see boost.
It's pretty obvious
what's your setup?
Old Oct 19, 2003 | 08:51 PM
Kazz's Avatar
Default Re: Cel three when boosting how to fix? (Johnyquest)
I just have a stock 96 teg with the greddy kit.. It never happened before.. Just started..
how would fix this problem..
Thanks in advance
Old Oct 19, 2003 | 09:00 PM
Kazz's Avatar
would this product fix it or i mean bypass it
http://www.overboost.com/obs/product.asp?pid=5509
Old Oct 20, 2003 | 08:03 AM
Johnyquest's Avatar
your blue box is either broken or incorrectly wired. check for function!
Old Oct 20, 2003 | 05:32 PM
Kazz's Avatar
the blue box is blinking if thats what you mean
should be wired correct cause it didn't happen before..
maybe broken
Old Oct 20, 2003 | 07:03 PM
madman604's Avatar
its supposed to blink. check the wires connected to the MAP sensor
xiLLtegRax
Apr 28, 2008 08:19 AM
kell211
Oct 8, 2003 07:00 PM
Burke
Jul 29, 2003 01:48 PM
Daniel
Feb 11, 2003 11:19 AM
Sivik
Feb 4, 2003 01:42 PM
