CEL question
Old Mar 10, 2004 | 06:22 AM
DSMfor me
Guest
Posts: n/a
Default CEL question
I just finished the turbo install. 450cc injectors and AFC. Car starts and runs fine. as soon as I start to build boost pressure the check eng light comes on. I clear code, start over, same deal. WTF?
91 CRX Si 1.6L.
Any Ideas?
Old Mar 10, 2004 | 08:35 AM
RacerXI's Avatar
Default Re: CEL question (DSMfor me)
Map controller seeing boost? I'm not familiar w/ the hack, but you might need some check valves in there. HTH.
Old Mar 10, 2004 | 08:38 AM
LostCRX's Avatar
Default Re: CEL question (RacerXI)
if you are not sure, then you shouldn't give out false imformation like that, just don't say anything at all.
You don't need any checkvalve/missing link with the hack. What codes are you throwing? make sure you install the afc right.
Old Mar 11, 2004 | 09:49 AM
DSMfor me
Guest
Posts: n/a
Default Re: CEL question (LostCRX)
MAP. Yep the AFC is wired correctly. I can drive the car all day if I dont let it spool and it will never throw a code. But, when I start building pressure, Its throws the code for the MAP
Old Mar 11, 2004 | 09:53 AM
G
sh!t happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostCRX &raquo;</TD></TR><TR><TD CLASS="quote">if you are not sure, then you shouldn't give out false imformation like that, just don't say anything at all.
You don't need any checkvalve/missing link with the hack. What codes are you throwing? make sure you install the afc right.</TD></TR></TABLE>
you dont need to say anything at all either......
i have the vafc hax and my car was doing the same thing and i put check values and it went away. i had to put 2 check values in.. what are the codes you are throwing???
Old Mar 11, 2004 | 12:07 PM
FastNFurious
Guest
Posts: n/a
Default Re: CEL question (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GUNIT &raquo;</TD></TR><TR><TD CLASS="quote">
i have the vafc hax and my car was doing the same thing and i put check values and it went away. i had to put 2 check values in.. what are the codes you are throwing???</TD></TR></TABLE>
You shouldn't be saying anything either.....
If you are running check valves than your not running "The hack". The point of the hack is too allow the map sensor to see boost. You are just bleeding the boost and using the VAFC to tune with, which is OK.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSMfor me &raquo;</TD></TR><TR><TD CLASS="quote">MAP. Yep the AFC is wired correctly. I can drive the car all day if I dont let it spool and it will never throw a code. But, when I start building pressure, Its throws the code for the MAP</TD></TR></TABLE>
Are your fuel corrections set right?? What are they? If it's set too rich than your going to get a cel.
Old Mar 11, 2004 | 12:17 PM
G
sh!t happens.
Default Re: CEL question (David555)
cool well my car is running good with them so i cant complain.....
besides us not knowing what were talking about what are the codes you are throwing so we can figure it out...lol
pwr_crx
Feb 16, 2006 10:01 PM
Discosteak
Nov 2, 2005 07:38 AM
94greddycivic
Jun 26, 2004 10:43 AM
2ltrsnailpwr
Oct 24, 2003 03:33 AM
platinum00
Jul 25, 2003 09:16 AM
