CEL 41 and 3 w/ Hack
Old Aug 25, 2003 | 07:17 PM
squirrel's Avatar
Default CEL 41 and 3 w/ Hack
I've got a B20Z converted to OBDI with a T3 turbo (@ 7 psi). I currently have DSM 450s and the VAFC. ( set at -35 across the board)
At low throttle and in vacuum the car runs fine (idle is kind of high though), but sometimes in boost the check engine light comes on and the car bogs.
Anways I'm throwing codes 41(Primary Oxygen Sensor - Heater circuit malfunction)
and 3 (MAP Sensor defective circuit or unplugged / defective sensor).
What can I do to remedy these problems? Any help is appreciated.
Modified by squirrel at 8:35 PM 8/25/2003
Old Aug 25, 2003 | 07:19 PM
eg6turbo's Avatar
Default Re: CEL 41 and 3 w/ Hack (squirrel)
sounds like u might have a bad o2 and ur map reading boost
Old Aug 25, 2003 | 07:34 PM
squirrel's Avatar
Default Re: CEL 41 and 3 w/ Hack (eg6turbo)
Could the placement of the O2 sensor be a problem? The O2 sensor is ~4" away from the turbo.
Shouldn't the hack eliminate the problem with the MAP sensing boost?
Old Aug 25, 2003 | 07:37 PM
eg6turbo's Avatar
if ur running hella rich u couldve burned out the o2 and cause the cel.....
also for trippin the map could mean ur boosting too much...above the 11.2 psi limit of the stock map....
Old Aug 25, 2003 | 09:43 PM
paulzy's Avatar
Dao, this is the exact reason why I told Keng to run a better fuel management setup...if you want something plain and simple, try a hondata.
The AFC hack has a lot of mixed reviews. Call me if you need a hondata setup
Old Aug 25, 2003 | 11:19 PM
oscarmayer's Avatar
I "read" how guys say the afk hack is great, But i have yet to "SEE" one actualyl work correctly and typed in the computer for online reading. I have actually seen more problems and blown motors due to attemtps with it than anything else.
Do the Hondata as already suggested. It works.......
Old Aug 26, 2003 | 08:37 AM
squirrel's Avatar
Default Re: CEL 41 and 3 w/ Hack (oscarmayer)
I was planning on switching to Hondata at a later date. For now I'd like to see if I can get this to work.
Hondata might have to come sooner than I think.
Old Aug 26, 2003 | 08:50 AM
Nextelbuddy's Avatar
i am running the VAFC hack on my b18c1 in my 95 hatch at 4-5 psi with no problems it runs great.
Old Aug 26, 2003 | 09:16 AM
Vtec92Civic's Avatar
Default Re: CEL 41 and 3 w/ Hack (nextelbuddy)
Same goes for me . . . . i'm running the AFC Hack and it works great for me (knocks on wood) my idle is great, and when in boost everything is good. I ha that CEL 41 when I first started up my car and that was because my o2 sensor was not hooked up right.
*if you have an air/fuel ratio gauge double check that your o2 is hooked up right*
Old Aug 26, 2003 | 09:39 AM
R6Elmo's Avatar
Default Re: CEL 41 and 3 w/ Hack (Vtec92Civic)
if your 02 sensor is literally 4" away from the turbo, that's your problem right there. Do yo know how hot those things get? It's not like putting an 02 sensor on a N/A header or something.
Put the 02 sensor further down where the downpipe meets wtih the cat.
Danny
sOLLEx
Apr 11, 2014 05:39 PM
turbohx97
Apr 26, 2008 08:36 PM
colnago
Apr 7, 2007 11:14 PM
Burke
Jul 29, 2003 01:48 PM
SIK IN DA HED
Nov 15, 2002 10:59 AM
