Oil Catch Can
Old May 27, 2003 | 12:29 PM
RyanEJ8's Avatar
Default Oil Catch Can
Does making one like this actually work?
http://www.tgilmore.com/talon/catchcan.html
Old May 27, 2003 | 04:54 PM
RyanEJ8's Avatar
Default Re: Oil Catch Can (RyanCivic2000)
ttt
Old May 27, 2003 | 04:56 PM
.RJ's Avatar
.RJ
this will work, but you really ought to have the catch can mounted inline after the PCV valve.
Old May 27, 2003 | 05:05 PM
RyanEJ8's Avatar
Default Re: Oil Catch Can (.RJ)
What do you mean? Isn't that what they did?
What I don't understand is how does the fuel filter "catch" the oil?
Old May 27, 2003 | 05:09 PM
.RJ's Avatar
.RJ
they mounted it on the vent tube on the valve cover. You will get some blow-by, but not much from there.
Old May 27, 2003 | 05:11 PM
10K2HVN's Avatar
LOL!! i thought of that idea!!! but i guess he went public with it first..oh well...
..but he doesnt have it hooked to the PCV hose that gets really oily! the one that you really want to filter is on the back of the block (B-series VTEC)! On B-series VTEC the valve hose sucks in air to the valve cover....
https://honda-tech.com/zerothread?id=514003
Old May 27, 2003 | 05:18 PM
.RJ's Avatar
.RJ
Default Re: Oil Catch Can (10K2HVN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10K2HVN &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=514003</TD></TR></TABLE>
This is wrong.... wrong..... wrong.....
Take the PCV off the valve cover/manifold and put your finger on it. Notice vacuum into the manifold.
Old May 27, 2003 | 05:29 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10K2HVN &raquo;</TD></TR><TR><TD CLASS="quote">LOL!! i thought of that idea!!! but i guess he went public with it first..oh well...
Its in the same place on D Series VTEC also, right?
Old May 27, 2003 | 05:32 PM
.RJ's Avatar
.RJ
mount it between the PCV and the intake manifold
Old May 27, 2003 | 05:45 PM
RyanEJ8's Avatar
and all i need is a $3 fuel filter and a hose then? What size hose, does anyone know? Also how much will this really affect the cleanliness/efficiency/or performance of my motor?
Old May 27, 2003 | 05:48 PM
.RJ's Avatar
.RJ
ideally, you want to do something like this:
http://www.theoldone.com/components/breather/
Old May 27, 2003 | 06:50 PM
dfoxengr's Avatar
thats what i thought...hmm
Old May 27, 2003 | 07:48 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Oil Catch Can (hybridvteceg)
I want to see one that has oil in it. I have yet to see one w/ oil in the fuel filter. I suppose it would work, but does it catch it all? And do you need to run two? One inline w/ the PCV and the other in the line from the hose that goes to the intake?
Blaze
Old May 27, 2003 | 08:34 PM
10K2HVN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Take the PCV off the valve cover/manifold and put your finger on it. Notice vacuum into the manifold.</TD></TR></TABLE>
are you stating that im wrong or the the artical from TeamIntegra.net is wrong??? honestly, i feel kinda offened..and i wanna staighten things up before i open my mouth.....
Old May 28, 2003 | 04:58 AM
Xsi's Avatar
Xsi
Just put a can of some sort between PCV and IM, any kind of can really as long as it holds a vacuum
Old May 28, 2003 | 06:23 AM
.RJ's Avatar
.RJ
are you stating that im wrong or the the artical from TeamIntegra.net is wrong??? honestly, i feel kinda offened..and i wanna staighten things up before i open my mouth..... </TD></TR></TABLE>
Why would you be offended? *shrug*
If you copied+pasted the info from somewhere else, you're not at fault.
Pull the t00b off the pcv valve and note the vacuum. Air is being sucked *into* the manifold.
Old May 28, 2003 | 07:30 AM
10K2HVN's Avatar
aight...
yes there IS a suction at the PCV tube that goes from the Block to the Intake Manifold. But, what i was talkin about was the tube thatgoes from the Intake Piping to the Valve Cover. Theres No Point in puting it there on B-Series VTEC motors Because the air flows from the Intake Piping to the Valve cover due to the Suction created from the IM when the Thoattle Body is closed.
IM sucks from Block, Block sucks from Head, Head (valve cover) sucks from Intake Piping! Placing the a filter between the Intake Piping and the Valve Cover is Pointless because filtered (unless you dont have an air filter) air is flowing from the Intake Pipe to the Valve Cover!
In that picture, the Gas Filter was in between the Intake Pipe and the Vlave Cover.
Old May 28, 2003 | 07:36 AM
.RJ's Avatar
.RJ
actually its a vent tube. On my old car i put a little K&N filter on it.. got pretty dirty after a while.
Old May 28, 2003 | 07:52 AM
10K2HVN's Avatar
B-series VTEC? with PCV on the block hooked-up? because i thought is was a venting system too but i read that article and it stated otherwise and i just tried to justify what it said.
also, it could get dirty (ur filter on ur old car) when the the throttle is open.. because the when the throttle is open air chooses the path of least resistance (like everything) and instead of sucking air through the PCV system, air just comes in through the TB. With throttle open, PCV is bypassed and building-up bypass gasses inside the crank and head will blow back out the valve cover thus getting your filter dirty. But when the throttle is closed again PCV goes back into action sucking fresh air in the Head and dirty/oily air out the PCV filter (back of block).
It does make sense, because the time you need the PCV system the most is when you start your cold car and your engine is not running efficiently and lots of bypass gasses will contaminate your oil and break it down slowly..so you would want to suck those gasses out....
Old May 28, 2003 | 11:18 AM
crxste's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">ideally, you want to do something like this:
Do you have any pictures of this installed on a B series????
Like which bit goes where etc
THEDirtyDseriesWOOT
Aug 31, 2006 01:23 PM
Weston
11
Dec 13, 2003 08:47 PM
UNDER PRESSURE
10
Oct 1, 2003 07:25 AM
Sinner
Jul 17, 2003 11:56 AM
GruvyTune
Oct 22, 2001 01:29 PM
