catch can
Old Nov 21, 2003 | 01:34 PM
JICEK9's Avatar
Default catch can
I know how many threads there are on catch can installation. I just got done searching for about an hour
anyways, I was thinking, could you run one line from your pvc valve into a tee along with the line off your valve cover and then into the can. and then on the other nipple on the can, run that into the pre turbo intake for the vacume? or wouldn't this be ideal? any other ideas/pics would be helful.
Old Nov 21, 2003 | 01:38 PM
baphomet's Avatar
Default Re: catch can (JICEK9)
from what I gather, the valve cover wants fresh air in vacuum - I would use two cans, no pcv, and a filter on both, one to get fresh air, one to expel, while not letting crap in, - and both cans to keep oil off the ground under boost. But what do I know.
Old Nov 21, 2003 | 01:46 PM
TeStUdO's Avatar
https://honda-tech.com/zerothread?id=684673
Old Nov 21, 2003 | 02:09 PM
JICEK9's Avatar
Default Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=684673</TD></TR></TABLE>
thanks, I've read it.
Old Nov 21, 2003 | 02:26 PM
TeStUdO's Avatar
Default Re: (JICEK9)
Here is the Endyn one and the write up of how they hook a breather up to the valve cove. See if this helps.
breather------ http://www.theoldone.com/components/breather/
write up------ http://www.theoldone.com/articles/badtothebone/
Old Nov 25, 2003 | 05:55 AM
JICEK9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">Here is the Endyn one and the write up of how they hook a breather up to the valve cove. See if this helps.
yea, Ive read this also
I just want to no if the car will run properly with no pvc system? I've heard it might smoke
Mjalaly
Jun 25, 2015 01:26 AM
fryman
Apr 3, 2013 04:12 AM
Johnny_Rocket
Apr 11, 2005 05:26 AM
Bambooseven
Sep 22, 2004 10:51 AM
Rod.
Aug 8, 2004 01:42 PM
