which catch can for me? Suggestions
Old May 30, 2005 | 12:31 PM
BoOsTiN Dc2's Avatar
Default which catch can for me? Suggestions
I'm in the market for 2 catch can right now. I've been looking around and i don't see too many options right now or maybe i'm just finding wrong info. I'm looking for a catch can with 2 inlets and a breather on top. One catch can is going to be for the 2 ports on the front of the valve cover, and the other catch can would be for the back the block and maybe even the valve cover nipple. Which catch can are my options?
Old May 30, 2005 | 01:08 PM
sohc hatch's Avatar
Default Re: which catch can for me? Suggestions (tRaCeBuStAbUsTeR)
Look up a thread by a user by the name of " dasher ". All the catch can information you need or will need is in that thread.
Can that fits your requirements would be an Endyn.
Good Day,
RH.
Old May 30, 2005 | 01:20 PM
Default Re: which catch can for me? Suggestions (egturbohatchback)
yeah but im not gonna pay like around $150 x 2 for cath can
Old May 30, 2005 | 01:28 PM
EnzoSpeed's Avatar
Ebay. A can is a can. Mine was $30 and works fine.
Old May 30, 2005 | 03:19 PM
BlueShadow's Avatar
Default Re: which catch can for me? Suggestions (EnzoSpeed)
A DIY catch can is another option. The NAPA store that is less then 5 minutes away drilled and tapped out a water temp adapter for me before for only $5-$6. So buy a PVC pipe or a small metal box, and buy some hose barb connections that are threaded on the other end. Have your nearby NAPA or machine shop drill and tap your container and thread in your barb fittings. Get a valve cover breather with a large diameter neck and get a matching metal neck fitted to the top of your container. Find some way to baffle the inside of the container with either steel wool or metal louvers.
https://honda-tech.com/zerothread?id=1239323
Old May 30, 2005 | 06:45 PM
EnzoSpeed's Avatar
Default Re: which catch can for me? Suggestions (BlueShadow)
There's a thread somewhere here in the archives about DIY catch cans and some guy used an old pepper jar. It was sweet.
Old Jun 2, 2005 | 05:17 PM
besides diy is there one that i can buy besides endyn that has 2 port? it seems like all of the ones i see are singlet inlet
541lude
May 11, 2012 09:42 PM
totsie7944
Oct 18, 2007 02:23 PM
crxsiperf
May 2, 2006 07:39 AM
ATS*Mark
Apr 25, 2004 08:57 AM
976
26
Mar 12, 2003 05:45 PM
